Connecting a VCR to an RCA model F20580WN tv
Problem is, what channel views the vcr?
Channel 91 is input 1 and 92 is input 2
Posted on May 27, 2010
  • 69 Answers
Ch 3 , but you may need to plug your OUT TO TV on the vcr to cabel line in on your tv and if
you have cabel, plug that in to ANT IN on your
VCR , or just use the A/V plugs if your tv
has them.
Posted on Jun 28, 2009
  • 32 Answers
Normally its your vcr that will tell this, not your tv. on the back of the vcr there should be (at least there always used to be) a little selector switch that you could choose which channel. normally it was set to channel 3, but you could pick 4 if you wanted
  • 67 Answers
Usually it is channel 2 or 3.
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Mar 02, 2009 | Daewoo DV-T47N VCR
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
Can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Dec 03, 2008 | RCA Televison & Video
RCA 32' colortrak plus connectiuns
If you are connecting the cable to the VCR, and using a cable TV type wire (CATV wire) from the VCR to the TV, this is not the same as an A/V connection.
The VCR should have a built in modulator. In some areas the VCR uses channel 3 or 4. In other areas they are using channel 5 or 6. You will have to refer to the user manual for the VCR to know the channel that is being used for the VCR. On some, it is written at the CATV output connector.
Turn on the VCR, and set the TV to the proper channel for the VCR. Select in the VCR's options to put its output to the CATV, or its channel output. Refer to the book on the VCR for details.
Jerry G.
Apr 20, 2008 | Televison & Video
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
