Home | LG | LHD45EL Dehumidifier | Same problem
LG LHD45EL Dehumidifier
Problem for LG LHD45EL Dehumidifier
Same problem
By davekoz2330 on Jun 28, 2009
had the unit for less than two years and it started icing up and not collecting water. got a frigidaire unit and am much happier. i still have the unit.. is it even worth getting repaired??? whats the typical cost?
Solution #1
posted on Jun 28, 2009
Not Rated)
old fart58
Rank: Guru
Rating: 88%, 66 votes
Dehumidifiers must be operated in an environmental temperature of 65 degrees of greater. If that condition is met and it still freezes up, the other possibility might be the fan that moves the air over the coils has frozen up and needs replaced. If it is that simple, then repair it, otherwise it's more that the cost of a new dehumidifier.
Was this helpful?
Yes
No
Popular Solutions for LG LHD45EL Dehumidifier
Questions and Unsolved Problems for LG LHD45EL Dehumidifier
Do you recommend LG LHD45EL Dehumidifier?
Answer
Answer
The dehumidifier powers on and immediately stops with display error code Ch 01 Bucket is empty,... (More)
Answer
the machine sounds like it's running fine. it turns on and off on its own, but the bucket is not... (More)
Answer
Consumer Reports gives this unit a very good rating but where can I buy one and what kind of... (More)
Answer
Got CH 01 code and dehumidifier shut off. What can I do?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG LHD45EL Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
