Question about DeLonghi DC312T 14-Cup Coffee Maker
Wont heat or brew!!
I have the exact same problem. I set it for auto, and it didnot brew, so I pushed button again, and it says "brew" but no heat, and no coffee.
Make sure the coffee maker is unplugged there's 120 lethal volts inside when plugged in!
This unit has a replacable thermal fuse. It's a "Microtemp" Thermal Cutoff Fuse G4A00. You can buy five on eBay for $2.70. There are two on this unit and they are in the base concealed inside a 3" white mesh that runs alongside the heater. You will need a security fladebladed screwdriver that you can make by filing a notch in the center of a regular screwdriver.
Posted on Nov 26, 2009
  • DeLonghi Master
  • 5,568 Answers
All coffee maker heating elements are protected by a thermal fuse. Since they all seem to come from China now, their intended failure temperature is all over the map; in other words, they go open before there is any reason to do so. These are typically welded to a tab on the heater element proper and are therefore not user replaceable. The only option is to replace the heating element as an assembly.
These devices are necessary as protection in case the thermostatic switch (90% Chinese again) fails to interrupt current when the design temperature is reached.
It isn't only our food that the Chinese are poisoning.
Posted on Jun 28, 2009
How do i program a black & decker model cm1050w to start coffee breding at a certain time?
I have one. It's easy. Push the program button. The little green light in the lower left corner will flash. The only tricky part is that you only have about 3 seconds to begin setting your time. After that the light stops flashing and you will be changing the regular time. While you are pushing the Hour or Minute buttons you have all the time you need to set your brew time, but once you stop you're back to the 3 second timer. Remember, if the light in the upper left side is on, the time is PM. To turn the timer on, push the Auto button and the little light in the lower left will come on and stay on. To turn it off, just push the Auto button again. Another caution, there is no "safety" for the Hour and Minute buttons. If you push either of those buttons while the lower left light is flashing you are changing the brew start time. If it is not flashing you are changing the real time. In other words, if you push either of those buttons at any time, you are always changing something. Happy brewing.
Sep 12, 2011 | Health & Beauty
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
It wont stop beeping
Is it still beeping? ;) It will beep if you have the automatic brewing programed and the grinder and it's lid are not in place.Once you have put the grinder back in place, push the small white button down that is on the grinder lid. The beeping will stop. Don't press the program button again or it will start beeping again...but if you do, just push that white button again.
Aug 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Can't find manual, how do you program to brew in the morning?
Each model is different, but the general procedure is to push the PROG button (or turn the dial to PROG), then use the hour and minute buttons to set the time that you want the coffee-maker to go off in the morning. Most models display "PM" if it is set for PM, but don't display anything if it is set for AM. The critical part, on models that have a PROG button, is to push the PROG button AGAIN to store the time. Then turn the unit to Auto-On. It will go off at the set time.
Cuisinart, however, has dozens of different models - it will vary by your exact model number. Most manuals are available on Cuisinart's website.
-Tha Mp3 Doctor
Feb 24, 2009 | Cuisinart Coffee Makers & Espresso...
Cna't find manual, how do you program to brew in
-Tha Mp3 Doctor xxx
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
How to program to automatic brew
For most Grind and Brew's, you can press the PROG button or turn the dial to PROG, then press the HRS button to change the hour and minute to change the time. The led will display PM if it is set for PM, but will not display AM if it is set for AM. After you have finished programming, press the PROG button. Now activate the AUTO-ON button or slide the dial to the Auto-On position.
But, like the person said, we would need your exact model # to be more specific.
-Tha Mp3 Doctor
Dec 29, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Wont brew a full pot
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process until machine runs full cycle.
May 27, 2007 | Cuisinart DGB-600 Coffee Maker
DeLonghi DC312T 14-Cup Coffee Maker Logo
1,510 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
