Question about HP PSC 2210 All-In-One InkJet Printer
Printer is not working
"Open the door and clear the carriage jam,then press enter".this message is coming.what I will do? Give the solutin.
  • 4 more comments
  • winkle51764 Nov 07, 2007
    keeps telling me to align the cartridges
  • Anonymous Nov 16, 2007
    keeps telling me to align the cartridges and i press enter and still will not print
  • zeec Nov 25, 2007
    Press enter to align cartridges is continually displayed. I can print documents while this message is scrolling but cannot use the copy function. Haven't tried to scan and have long lost the fax function (am going to try to set up fax again though). I have aligned and realigned and changed and checked cartridges. Have turned off printer and computer, unconnected printer from computer and left to rest. Etc. Cannot get rid of align cartridge message. Tonight I think I'm going to try uninstalling and reinstalling printer. Cheryl
  • Anonymous Feb 18, 2008
    I have switched off at the plug then switched back on, I have made sure the is no jam
  • Anonymous Jun 12, 2008
    I put in a new cartridge and the "align cartridge" message scrolls. No matter how many times I align the message reappears and no copying is allowed. Have unplugged, shut down, reinserted the cartridges, etc. All failed to fix the problem.
  • Anonymous Dec 16, 2008
    Also cartridge does seem jammed. How to unjam?
Hold set-up button and , still while holding set-up button, press the option button, should be ready to go now!
Posted on Feb 13, 2008
    Problem Solver:
  • 14 Answers
Posted on Jun 13, 2008
The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Posted on Dec 28, 2007
Disconnect the printer fom electricity, wait for 2 min.
Then plug it again and open the door to realese the cartrige.
If cartrige is not centered puse enter and wait.
After removing cartrige consider replace with new one.
Posted on Dec 02, 2007
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cartridge jams
remove the cartridge and directly off the printer let the carriage remain in center.then with your hand manually move the carriage from left to right.3 to 4 times.then on the printer and insert the cartridge after cleaning it with dry tissue.then check out.also in the back side of the printer there is access door to remove the paper if jammed so check out there also if any paper jammed.
Apr 01, 2009 | HP PSC 2210 All-In-One InkJet Printer
Carriage jam message
unplug the power cable without powering the printer off,
press and hold # & 6 on the printer ... while holding these two keys connect the power cord and do not release the keys till the screen turns off. press the power button to turn the printer on ... it ll go through a reset and it ll be working fine, if the issue persists let me know
May 23, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Carriage Jam
Hi, Jim
Solution to your printer is to pull out your mains plug and put back let the printer set it self again it should let you remove your
cartriage out.
Jan 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
410 people viewed this question
Ben Johnson
