Question about Sony PS-LX300USB Turntable
The belt has come off how does it fix back on?
This has been in storage for a while and when i re set it up the belt was not on. how do you put it back on again because i am not sure which bits it needs to loop round?
  • 441 Answers
First place the belt onto the bottom of the turntable, it will be kind of snug but not very, replace turntable onto centerpin, remove rubber disc, spin the turntable slowly and look thru the opening at the same time, on the right side you will see a gold colored post, that is what you want to run the belt over, just pull it away fron the turntable and around the post
Posted on Jul 07, 2009
  • 69 Answers
Might help?
The drive belt is fitted under the platter. When assembling the
player, please handle the drive belt with care.
• Remove all packing materials attached to the tone arm, except
that on the stylus, and then open the dust cover and assemble.
Remove the stylus cover after assembling.
Hold the platter by the holes at its outer surface, and
then carefully lower the platter so that the center
spindle enters the center hole.
Rotate the platter until one of its outer openings is
aligned with the driving roller. (Refer to illustration.)
Gently grasp and pull at the ribbon tape of the drive
belt that is would under the turntable, and then
extend the belt around the driving roller. (After
attaching, remove the ribbon tape.)
In order to make sure that the drive belt has been
correctly fitted, slowly rotate the platter 3 or 4 turns.
Place the rubber mat on the platter.
Posted on Aug 07, 2009
  • sam brown Aug 07, 2009
    might help?
Need diagram for 1997 toyota camry 2.2 timing marks
Quick fix timing TDCproblem 0. Jack up car on passenger's side, block up for safety. 1. Remove tire #17 lug bolts
2. Remove skirt #10 2 bolts
3. Set crank to TDC "0" #17 bolt on crankshaft. 4. Loosen Power steering pump adjuster bolt #14 remove beltoff pulley. 5. Push PS pump back to fire wall far as possible. 6. Remove both bolts lower dog bone #14 bolts. they are a dog to get off.
6b step one withbraker bar get them loose. 6c Get smaller 1/4" socket wrench to fit on it. #14 1/4 to slip on it in a tight place. 6d Removebolts. Put in lower bone bolts in a cup for i.d.
7. Remove upper dog bolts. Put it upper dog bone cup. 8. Take out dog bone. parts 9. Remove bolts holding in upper timing belt cover. put intiming belt cover cup. 10. Remove upper timing belt cover. Yellow 11. unlock tichner #14 push down on tinchner lock it to makeloose belt. remove thespring with needle nose pliers if it makes it eazy. 12 MOVE CAM TO SEE THE HOLE AND THE ROUND HOLE BEHIND IT,NOT THE OTHER MARK.AS THE BOOK SAYS. THE ROUND HOLE IS ABOUT 5DEG BEFORE THESLIT MARK THAT YOU DON'T WANT TO USE. 13 SLIP THE BELT BACK ON CENTER THE TENCHIN ON THE BELT INBOTH DIRECTIONS FROMTHE CAM SHAFT. ONE TOOTH BACK OF FOWARD RECHECK CAM ANDCRANK MARKS. TIGHTEN IT UP TIME. 14 RELEACE TISHINGNER, TIGHTEN BELT PUSH CAM TO THE LEFT. TO GET TIGHT INBOTH DIRECTIONS TEST FOR PLUCK TONE. 15 START UP CHK TIMING WITH LIGHT. 16 BUT POWER STERING PUMP BACK TIGHT. 17 PUT TIMING COVER BACK ON 18 REINSTALL DOG BONE 19 PUT SKRIT BACK ON 20 PUT TIRE BACK ON. TEST IT ON 3 TRIPS.
Oct 13, 2010 | Toyota Camry Cars & Trucks
I just bought a set of Gemini 500 the belt has come off and I am usure how and where it fixes back on???
HELLO
This should be straightforward. Take off the slipmat and lift off the turntable (platter) and you'll see there is a rim on the underside of the platter this is where the belt goes.
Put the belt round that rim and you'll notice a couple of holes in the platter itself. Hold the belt through one of these holes and put it back on the tunrntable while taking notice of the motor position on the deck.
When the platter is in place (still hold belt) and move the platter to the position of the motor pulley and slip it on. Manually turn the deck once or twice to make sure it is in place - DONE! Replace the slipmat.
ENJOY! (:-)
Sep 13, 2009 | Gemini XL-500 Turntable
How do I **** the air out of a storage bag?
Facing the front of the machine,turn the belt lifter knob counterclockwise till it stops.Lift the headlight hood and unlatch the brushead from the machine.Place the large end of hose to machine,and lock it down.You are now ready to remove the air from the bags.
Note:Anytime you have to remove or replace the brushead,make the belt lifter knb the first thing you turn when removing,and the last thing you turn when reinstalling.It will save you alot of confusion in the process.
Dec 16, 2008 | Vacuums
HOW TO REPLACE BELT ON kIRBY cLASSIC 111 vACUM cLEANER?
I don't have a diagram, but I might be able to explain it to you.
Take the nozzle off the machine. Remove the brushroller and old belt.
Set the belt pulley to the on postion. Put the belt on the roller and put the roller back into the roller housing with the belt centered. Turn the belt pulley to the off postion. If you look in the hole in the back what you want to happen is the pulley to spin and hook the belt stretching it out.
Put the nozzle back on the machine. Lock it into place and turn the pully to the on postion, and you should be ready to go.
Nov 25, 2008 | Vacuums
Fitting cabriofix car seat with seatbelt only
yeah i had a cabrio and just fitted it in car with the seat belt the part of the seat belt that would go around your waist goes over the front of the carseat and over were the baby would be sitting there is clips at either side just below the carryhandle put the seat belt through them then put the part of the seat belt that would go around your neck round the back there should be another clip in the middle of the back above the storage part if you put the seat belt throgh it then clip the buckle in and pull tight the car seat should be secure hope i explained it easy to follow.
Oct 28, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
HP PSC 2175 Cartridge Belt
Ok, I will try to explain how I fixed mine as best as I can. I took it all apart and realizing that the belt moved the cartridge carriage I thought 'hmmmm' and took the belt, cleaned it and the cartridge carriage and in the channel on the carriage where the belt sits (sort of W shaped) I put some 'Gorilla glue' and put the broken ends down into the glue. I let it set up for about 6 hours and my printer has been back up and running ever since. That fixed the broken cartridge carriage belt for me. Now if the other belt breaks then I guess I will have to break down and buy another printer but after 6 years of service I can't complain. And yes I have been refilling now for over 4 years. I hope this helps.
Kazdagi
Jun 22, 2008 | HP PSC 2175 All-In-One InkJet Printer
How to replace belt in jvc turntable
I just got a JVC turntable from a thrift shop today and as soon as I got it home the belt broke. I had a replacement but couldn't figure out how to install it. After taking off the back, which is about 4 screws plus the 4 feet and the grounding screw, I saw a very tiny set screw on the post where the spindle obviously is. I removed this and the table came right off so I could replace the belt. I couldn't get the tiny set screw back but figured I didn't need it and if I ever have to replace another belt, I won't have to take the back off anyway. I hope this helps.
Jan 02, 2008 | Audio Players & Recorders
Curtis mathis tv
sadly,,it should be retired...the cm sets were good in their day,,but the money would be beter invested in something that will be ready for the digital airways
Nov 27, 2007 | Televison & Video
Sony PS-LX300USB Turntable Logo
780 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
