Question about GE WBSE2090A Top Load Washer
Whirlpool heavy duty washing machine leaking brown oil, worth repairing?
  • Official Brand Answer
  • 408 Answers
Hello Consumer. We truly apologize for the frustrations you have experienced with your washer. If you would like us to look further into your concerns, please email us directly at Whirlpool_Digital@Whirlpool.com . Please include your name, YouTube User ID, complete contact information, the full physical address where the washing machine is located, along with the model and serial numbers. Sincerely, Andre W.
Posted on Jul 09, 2014
5 Suggested Answers
SOURCE:
SOURCE: ge washing machine, trying to
My solution was, I didn't want to pay $14.99 just to find out if the machine was a heavy duty washing machine. That's why I quit.
Posted on Oct 09, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Posted on Feb 26, 2009
landsend
  • 1066 Answers
SOURCE: Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Posted on Apr 01, 2009
  • 1738 Answers
SOURCE: GE 10 speed heavy duty washing machine stopped
Sounds like you tinmer is not advancing. Try advancing the timer manually to see if this starts agitating.
Posted on Aug 14, 2009
How do i find out whats wrong with my washing machine? The brand is whirlpool heavy duty
check for a clogged filter screen on the cold side of the water inlet valve,the cold water shut off, or the hose kinked
good luck
Feb 28, 2013 | Whirlpool Clothes Washer Heavy Duty...
My Whirlpool washing machine leaves the clothing wet and it is leaking oil
More than likely the transmission is leaking oil and it has gotten on the clutch. That is probably why it is not spinning enough of the water out of the clothes. Some Whirlpool washers have an extended warranty on the transmission so it might be worth looking into that. If there is no warranty left you will be looking at a pretty expensive repair. I would say around 3 to 4 hundred dollars to replace the transmission and clutch. Hope that helps.
Aug 30, 2011 | Washing Machines
Water not coming inside the washing machine
Water not coming inside solutions:
1. Make sure the inlet has water or the faucet going into the washing machine inlet has free flowing water.
2. Did you turn on the machine on?. This is required specially for heavy duty 10kg Whirlpool industrial grade washing machines..
3. If the two above didnt work. Try rotating the knob to NORMAL and pull it.
4. Contact the nearest Whirlpool service center for repair if problem persists.
Hope this helps
levibit
Dec 13, 2010 | Whirlpool Washing Machines
Whirlpool washer leaking oil from bottom. is it gearbox or transmission? is it worth repairing?
It is gear box. Rebuilt on ebay about $100. New on Ebay about $185. Washer has 13-15 ounces of oil. Unless you have a big puddle, keep using it.
Oct 27, 2010 | Whirlpool Washing Machines
Kenmore heavy duty washer leak oil out while putting belt on where do I put oil in at and what kind of oil
It sounds like your tansmission seal is leaking. I don't know of any washer you put oil in.
Jan 06, 2010 | Kenmore 23822 Top Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Washing machine leaks
Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
May 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water rinse just trickles on my whirlpool heavy duty top loader
There is a screen inside the inlet valve that is most likely plugged. Turn off the water and remove the cold hose from the washer inlet valve. You can see the screen just inside the valve. If the particles are a light brown color, it may be water softener resin, requiring a softener repair. Foreign matter can also include sand or other particulates in the water supply.
Apr 25, 2009 | Washing Machines
GE WBSE2090A Top Load Washer Logo
53 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
