Question about Juki DDL-8700
I purchased a used Juki DDL-8700-7 and I'm having difficulty sewing hemming pants over the thicker areas. It didn't come with a manual. I'm new to sewing, so I don't know how to adjust the tension to the bobbin. It sews fine using a size 10 needle, but the top thread breaks as soon as it reaches the thicker area. I switched to the size 16 needle, but breaks the needle every time. I'm not sure what to do. Please help. Thanks. Gail
  • 106 Answers
SOURCE: problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Posted on Mar 29, 2008
yalmer
  • 552 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
  • 980 Answers
SOURCE: Hi I have 5 Juki DDL-8700-7 machines and I need to
So many machines you would be best at aution as one complete lot.
Posted on Oct 29, 2009
  • 980 Answers
SOURCE: is there a simple way to slow the speed down on a
On the motor where the clutch is you will see thge large pin with a nut on it, as you press on the pedal the pin engages with the motor, if you loosen the nut and unscrew the pin bit by bit and try the machine you will get to a point where you will have absolute control on the speed.
Posted on Nov 05, 2009
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Mar 07, 2015 | Juki DDL-8700
Juki ddl8700 assembly manual
hi there
you can visit www.juki.com.jp under industerial sewing machine you can download instruction manual for DDL 8700 manual or email me i can send to you.
best regards
aabozid@hotmail.com
Nov 13, 2010 | Juki DDL-8700
Obtain Juki Industrial User's Manual 8700-7
hi there
u can find at www.juki.com under industerial sewing machine
u can download DDL 8700-7 instruction manual
best regardes
ashraf abozid
aabozid@hotmail.com
May 23, 2010 | Juki DDL-8700
Problems when sewing over heavy jean hems
Mar 29, 2008 | Juki DDL-8700
Juki DDL-8700 Logo
229 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
