Question about Phase Linear UDV9010 Car DVD Player
BYPASS EMERGENCY BRAKE WIRE
THE EMERGENCY SCREEN APPEARS IT TELLS YOU IT UNLAWFUL TO DRIVE LIKE THAT BUT MY SCREEN ALSO CONTROLS THE RADIO SETTINGS
  • 49 Answers
Unhook your E-Brake wire and do the following:(2 options depending on DVD Unit)
If you have the old firmware then all you need to do is ground the parking brake wire
OR
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Posted on Jun 29, 2009
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
Jan 31, 2011 | Jensen Car Audio & Video
When a dvd is in a warning comes upsaying it is unlawful to operate dvd without emergency brake on. Is there a bypass code?
There are many DVD's players that will not operate while in motion or in drive. You will need to take it to a stereo shop and have them by-pass the warning.
May 16, 2010 | Car Audio & Video
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
How would one bypass the emergency brake to view a dual 7 inch touch screeen while driveing
On the radio wiring harness grond the wire that is marked emergency brake sensor/light wire. Be advised that it is illegal to have a dash mounted video player active while a vehicle is in motion, reason emergency brake has to be applied in order to watch.
Dec 26, 2009 | Panasonic CQ-VD7001U 7 Inch (Diagonal)...
Emergency brake wire connection
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Apr 12, 2009 | Jensen's VM9312 Car DVD Player
Bypass emergency brake switch on 92 Legend w/Kenwood DNX7100
ground the green emergency brake wire just hook it into the radio ground and that will fix it
Nov 29, 2008 | Kenwood DNX7100 Car Video Player
Linear uv7
GROUND THE PARKING BRAKE WIRE DIRECTLY TO GROUND OR 12VOLT WHICH EVER IT CAUSE FOR WHICH IS USUALLY GROUND. U MAY ALSO HAVE TO INSTALL A TOGGLE SWITCH TO . CONSULT UR USERS MANUAL ON THE PROCESS FOR ACCESSING THIS FUNCTION
Aug 16, 2008 | Car Audio & Video
Venturer cd/dvdcar head unit
Ground the brake wire(light green) to the frame. Goodluck.
Mar 07, 2008 | Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
HELP!!!!
there is a blue wire with a yellow stripe on this unit that if you hook it straight to ground you will never have to worry about it again.... This wire is actually the parking brake wire which only is to allow you to watch movies while you are stopped and the emergency brake is engaged but if you take it and hook it straight to ground it will bypass all that crap...
Dec 29, 2007 | Pioneer AVH-5700DVD Car DVD Player
Phase Linear UDV9010 Car DVD Player Logo
691 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
