Question about Refrigerators
Freezer not cooling on my whirlppol side\side.  fridge is barely working. Cleaned the main coils with no change.  Pulled apart the freezer and the condenser is warm (bright silver coils) and I do not hear the compressor coming on - just a click. Any help is appreciated.. The model # is ED25QFXHW
  • 544 Answers
HI.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Jun 28, 2009
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 07, 2012 | Amana Refrigerators
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
Maytag side by side. Coils froze solid, no cooling in fridge or freezer. Replaced heat coil and thermostat assly., as well as adaptive defrost control (circuit brd.). Still don't seem to be able to...
Hi Rob,
The problem in your case is most probably with the defrost thermostat.
It can be found on the evaporator i.e. freezing coils , it's round disc like with two wires.
If you get this replaced with a new proper working unit ,
Also make sure you replace the defrost timer as well if the problem persists.
Hope this helps ..:)
Jun 24, 2011 | Refrigerators
I just moved into an apartment that has a side by side amana 22 refrigerator in it. The freezer section is fine everything is frozen and the tempeture is where it should be. The fridge side however, is...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Amana Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Freezer o.k., Fridge barely cooling.
Expose the coil in the freezer and defrost it with a hair dryer.
Aug 01, 2009 | Refrigerators
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
