When copying an original
SOURCE: Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
SOURCE: Actually a Canon PC-65, problem follow-up
canon older model PC_6RE problem: the third copy and byond, streeks appear on the left side, progreesivly get worse on each additional copy, a wait of about 2,hours, then the 1st copy is clear again, any solution for this?
SOURCE: BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
SOURCE: PC 940 Canon Copier help with cleaning
Hello sir; Discharge corona unit dirty it cause this problem, got to be discharge corona wire covered by tone, clean outby rubbing alcohol,it will take care your problem.
SOURCE: canon imageCLASS D320 printer driver for windows
Driver download link: Canon imageCLASS D320 Multifunction Printer Driver
