Question about Hitachi 36SDX88B TV
The unit seems to be turning itself off. no image
The unit seems to be turning itself off. no image ever appears
  • 378 Answers
Check any loose connection in PCB , re solder the component lead.
Posted on Jun 28, 2009
Display image cannot be deleted and seems to be part of a time-set procedure?
If you wish to get some details about microwave oven repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 13, 2016 | In Microwave Ovens
Error code l 4 01
L4-01 is a main motor lock error. More than likely something is locked up, rather than a problem with the motoer itself. Make sure the drum and Developing unit are turning freely. The Fusing unit binding can also cause this error. Turn the machine off, remove the developing unit and the drum. Put the developing unit back into the machine, close the doors and turn it on. If you can hear the motor run and there is no error code, then the drum is locked up, probably due to a flipped cleaning blade. The next area to check is the developing unit itself. Sometimes if the bushings go bad at the ends of the developer roller, it will cause a motor lock. There is a white coupling on the rear side of the developer unit. Turn it counter clockwise about a half turn, being careful to hold the unit level. There should be little resistance. If all seems O.K., then the Fusing unit is probably the cause. Also pull out the paper cassette and make sure nothing is preventing the pick up rollers from turning.
Aug 02, 2012 | Sharp Office Equipment & Supplies
Fittef what I pressume to be 2 new imaging units to my Bizhub C350 and a malfunction code has appeared C-001A can you tell me what the problem could be?
Sounds like one of the units may be bad as the C001A code means that the Color Imaging Unit drive motor is not turning. It would make sense that if you got this code immediately after changing an imaging unit, that if one was locked up it is now keeping the motor from turning and thus generating the code. In any case the C001A code means the color imaging unit drive motor is not turning.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 15, 2010 | Office Equipment & Supplies
Hi, I seem to have a problem with my Finepix Z1 digital camera. When I take a shot it seems to work ok, and the initial review image seems fine as well. But when I go back and review the image on the...
The clue is with the video.
The video function does not use the shutter. Lines on photo's or over exposure is due to the shutter not closing completely over the lens when you take a picture.
It will require cleaning which means opening up your camera and accessing the lens unit
Oct 28, 2009 | Fuji FinePix Z1 Digital Camera
Camera seems to think that the lens cap is on, there is no image (and no the lens cap is not on)- jvc mini dv camcorder gr-d347u The message "Lens Cap" appears when the camera is turned on, there is no...
There are 2 possibilities for that symptoms in JVC GR-D347U camcorder is either aparture in lens mechanism is stuck and does not pass image towards CCD Imager OR ccd imager itself got bad.
Qualified camera tech can fix it because it requires expertise.
If you want to fix it, download service manual from HERE for small fee, that will help you how to disassemble/ apart camera and part info etc.
Thanks.
Aug 13, 2009 | JVC GR-D347U Camcorder
Xerox Phaser 7750 Imaging Unit Percentage Question?
turn macine off wait 5 min repower and run recheck
Apr 06, 2009 | Xerox Phaser 7750GX Laser Printer
Logik LM101DU
I had the same - turned the power off overnight and the unit seemed to 'reset' itself and work. Davep.
Mar 10, 2008 | Audio Players & Recorders
Minola print smudge
Pleas check the imagine unit drum, is it clean or does there are the same marks as in paper.
if yes, the IU drum cleaning or drum itself is damaged and needs to be replaced.
Try:
after sending a print job, when printer has take a paper from tray, open cover, open cover before the paper enter the fusing unit, then you can see, if the mark is allready in the paper then the problem is in the IU or toner cartridge, if not, then fusing unit rollers.
Dec 31, 2007 | Konica Minolta magicolor 2400 Laser...
Viewfinder out of focus
Hello nikkid, E..:.. indication means that you should contact the nearest Sony Service. Possibble cause of this error can be the optical unit itself. Best regards, Arpad
Mar 13, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Hitachi 36SDX88B TV Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
