Renewed key fob battery but getting no response from any locks, no flashing indicators, can hear lock operating when using switch situated at rear of handbrake.
SOURCE: Noisy central locking Nissan MIcra
Hi there, this is a very common fault, you need to replace the drivers door actuator to stop the noise, ive done loads of these. hope this helps.
SOURCE: Sorry my car was not
You are going to need to check the power lock control moduel on the inside of the door panel. If the FOB appears to be working but the doors are not unlocking, you need to check this. I would also replace all fuses that control the locks. If both of these devices check out ok, you may need to replace your FOB. To check your power lock control moduel, manually lock and unlock your doors by pressing the lock button on the inside of the door. If it does not work, it is either the fuses or the power lock control moduel. If it works, your FOB has gone bad. Hope this helps! Please rate 4 thumbs up!
SOURCE: how do i reset central locking on a micra 04 reg
Try the following:
"KEY FOB PROGRAMMING
NISSAN
SYSTEM DESCRIPTION
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and hazard reminder. When the doors are locked and
unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed.
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Then turn ignition switch to OFF position. Leave key in ignition switch.
3. After 2 seconds, the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key?s.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key?s for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds."
Remote Control Fob Procedures:
the door locking, door super locking and emergency hazard reminders.
When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed:
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
control plip key.
Procedure:
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
8. Repeat procedure 4 to 7 for up to 4 plip key's.
10. Remove key, and check all plip key's for operation.
for 120 seconds.
http://www.autokeysquad.com/nissan-fob-programming
i hope this can help you.. :)
ps. I have tried resetting the key fob, swtching ign. on and off 6 times etc. but I get no response from indi. lights to say the system recognises this! I have also dissconected the battery for 20mins then reconnected it, waited 20 mins. still no response from system!
