Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Hoshizaki condensor fan motor is not working
What is the sequence for the condensor fan motor on a km500mae
commerical ice maker and what would cause it not to work?
it is a hoshizaki.....
    Sergeant:
  • 340 Answers
Too long to explain sequence here. but in the harvest mode the fan will not be running. go to hoshizaki.com you will find every thing you need very helpful site . and a clean machine is a happy machine. hope that helps Tom
Posted on Jun 28, 2009
    Problem Solver:
  • 7 Answers
If the waterpump is running, condenser fan motor should be running.
Posted on Feb 28, 2015
Operation of water pump on km500mae hoshizaki
I have found that if the pump runs in the wash cycle but not in the ice making postion, the switch is bad. strange but I have had this happen multiple times.
Oct 08, 2013 | Hoshizaki Freezers
Making noise while running
most likely a $450 water pump. or if it is not a remote condensor unit and has a fan then hopefully its only a $35 fix. I have seen the fan blades crack near the hubs ..
Sep 01, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Compressor cycling
chattering relay can cause compressor to over heat. replace that first and see if that does not resolve your issue.
Jun 06, 2013 | Hoshizaki Freezers
Hoshizaki km500mae just has continuous water flow through it. The only time it shuts off is when it is harvesting ice. This water is causing a huge water bill. Any suggestions?
You have an assembly that closes the water down when it is harvest ice. It is broke or out of adjustment. Have a rep look at it.
Feb 21, 2013 | Freezers
Siemens American fridge freezer with ice maker, freezer too warm and pipe that water flows from to ice maker is hot, not making ice?
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Siemens Freezers
I have a Hoshizaki KM900MRH ice maker. It will run fine for a couple days then shut off and beep 3 times within 3 seconds. I am told by tech support that it could be a float switch. Where is the float...
float switch is usually a white plastic unit with a black rubber boot on the bottom. you need to drain the water out of the sump before doing anything with the float.
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
How far can the condensor be located away from ice machine
Their web site has all your answers. Their tech support line is worth the wait. 1-800-233-1940.
I usually don't exceed 25 feet. If it is a straight up install, that is, the remote is on a roof, you may have to install traps to ensure proper oil return to the compressor, Otherwise, it will lockup on ya.
Jan 16, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Machine turns on makes one or two batches of ice and then shuts off
Try cleaning the condensor coils. Check the fan blowing across them. When the compressor is running the fan should be too.
Jun 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
386 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
0duro
Level 1 Expert
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
