Question about Teac MC-D95 CD Shelf System
Clock runs slow. Is there a button battery to change?
    Novelist:
  • 103 Answers
The cpu's in these units use extrememly little power for the clock, unlikely that low battery voltage is the cause, unless the battery is extrememly low, then yes it would be the battery, but also the unit might not use a battery but instead use a "super cap", which is a special high capacity capacitor that can hold a charge for weeks before needing to be recharged...they are usually rated for approximately .47 farads at 5 volts and they look like button batteries but are not....if yours uses super caps instead, then it might be on its way out, not able to hold a charge any longer because of deterioration....you might need the super cap changed.....also have the unit checked for bad connections....all solder joints, etc...which is always a big problem with any electronics...sometimes, solder looks good mechanically but electrically not good so it's a good idea to have the board resoldered.
hope that helps.
silvio
Posted on Jun 28, 2009
Battery operated George Nelson Ball clock running slow
Probable cause is low battery voltage, maybe the battery was not fresh or was of too low quality. For such a nice clock, extra cost in getting an Energizer Ultimate Lithium or VARTA Professional Lithium cell is justified and the AA sized battery with 3000 mAh will work for many years. Otherwise, use Alkaline batteries and don't forget to check the expiration date always. Check http://www.batteryshowdown.com/results-lo.html to get some ideas on what to buy and what to expect.
Mar 05, 2014 | Home
Clock runs 5 minutes fast
Do you mean you set the correct time initially and then gradually got faster?There may be a reset button on it somewhere,no guarantee.It will probably be a small circle that doesn't look like anything.If there is,press it with a sharp pencil or something just as small.If not,it's just the nature of the beast.I have a radio which slows down over time...and it's a BOSE wave radio and have to adjust periodically!That's about all you can do is deal with it.Sorry if you can't fix it. Good luck!
Jul 25, 2010 | Equity Time USA Sky Scan 44100 Clock Radio
Dacor ecs230 clock button is not working
there may be a backup battery built in to this unit to keep the clock running in case the power goes out. depending on the age of the unit, it may need to be replaced. the battery size and number as well as it's location should be in the owner's manual.
Aug 25, 2009 | Dacor ECS230 Epicure Electric Double Oven
Laptop's clock runs slow.
A near flat battery will cause the laptop to lose the time and date even if you change the BISO time and date, it will still lose time.
To get into the BIOS setup press F2 as you boot up the laptop.
Check the various settings and you will get to the time and date setting, follow the screen instructions to set the time and date.
I suggest you get a new battery installed before you change the time and date.
Mar 16, 2009 | Toshiba Satellite A105-S2031 Notebook
Slow clock
Is there a separate battery for the clock memory? If so I would try changing that. Otherwise the clock is probably busted. Digital clocks would not normally loose more than a few seconds a year. If the clocks crystal oscillator broke it may cause this. That could happen if the crystal was not glued down or came loose.
Jun 26, 2007 | GE 29439GE2 Corded Phone
JCR-160 clock radio Clock running slow
The clock works off the frequency (hertz). In US the electrical wave frequency is 60HZ/sec and in India and many other countries 50HZ/sec. Hence, the clock slows down about 6 seconds or so every minute.
Mar 12, 2007 | Jensen JCR-425 Clock Radio
Teac MC-D95 CD Shelf System Logo
136 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
