Question about Kenmore 22422 Top Load Washer
I have a Kenmore top load washing machine. It
I have a Kenmore 70 series top load washing machine. It won't spin as fast as it should and when you open the lid it makes a loud banging noise as the drum comes to a stop.
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore series 70 washer will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Kenmore washer series 70 wouldnot drain water
heatman101
Jul 23, 2011 | Kenmore Washing Machines
Washer does not spin, broken belt? kenmore series 70 top load
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 28, 2010 | Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2009 | Kenmore 22422 Top Load Washer
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
Kenmore 70 Series
check the balance ring on the top of the basket it has either came loose from the basket rim or the fluid inside is not there
might need a new one
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Let me know if it worked..
Oct 17, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
106 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
