Question about Sony PlayStation Portable (PSP) Console
Psp usb mode problem
My PSP won't go into usb mode when hook it up with the usb cable 2.0 I NEED HELP!
    Problem Solver:
  • 6 Answers
You have to have your psp on when you connect it, then you have to go to where it says USB and select that for it to connect
Posted on Jun 29, 2009
3 Suggested Answers
NinjaUK
  • 164 Answers
SOURCE: PSP USB Mode
It may just be that your laptops software isn't compatible with your PSP's
Posted on Aug 21, 2008
reyjoshua07
  • 1157 Answers
SOURCE: my psp cannot connect via usb mode
Hi rin1_02, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Posted on Feb 04, 2011
My computer dosent run my psp program with a usb cable so i can sync anything in, how do i make it recognize my psp
When you connect your PSP to your computer, it won't recognize the PSP immediately. After you connect the PSP, you will have to navigate to USB Mode on the XMB. Your computer will recognize your PSP as a mass storage device.
Good Luck.
Mar 18, 2011 | Sony PlayStation Portable (PSP) Console
I just bought the cables for my PSP 3000 to hook to my tv (the set with the 5 wires) and I have tried hooking it through all of my ports and I do the hold the display button for 5 seconds and the psp goes...
1. Connect your PSP with your PC using the USB cable.
2. Use your PSP interface and hit HOME button, and then go into "Settings". Here you will have to use the directional button to find "USB Connection"
3. Once the connection is made, you will need to check your PCs available drives. You can do this by going into "My Computer". Your PC should detect your PSP as and additional drive. It is not much different from using portable drive or thumb drives actually.
or better u download repair guide
click here to download repair guide
Dec 16, 2010 | Sony PlayStation Portable (PSP) Console
My pc does not read my psp, how do i fix it.? do i need to install a psp driver.? where do i find such driver for free.?
Hook up your Sony PSP to your computer via a USB cable. Turn on the PSP and put it in "USB CONNECT " mode (it should display the words "USB CONNECT" on the PSP display during the entire time you're transferring files, and plug it in if you don't have a fully charged battery).
Apr 02, 2010 | Sony PlayStation Portable (PSP) Slim...
I cant charge my psp with usb
go to settings and check that usb charge option is on... and ake sure its in usb mode
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
Keep plugging in the usb cable and different things pop out
Your psp is in Flash 0 mode. To take it of Flash 0 mode you turn off your psp completely. Once thats done you want to hold the R button and turn on the psp while holding R. This will take you to recovery mode. Only do the step that tells you to click Flash 0
Jun 23, 2009 | Sony PlayStation Portable (PSP) Slim...
I want to connect a cctv camera to psp
yes indeed. you need simply a usb to mini usb hub cable ( about 15 bucks) and hook it in, go to usb mode on the psp it will have a few options. naturally th epsp wont recognize the system immediatelt, so give it time and all will be solved. if this doesn't work, then i recommend changing psp settings on your computer to allow the psp tpo recognize it immediately.
Apr 19, 2009 | Sony PlayStation Portable (PSP) Console
Cant get computer to recognize the psp
First, make sure the music you are wanting is in mp3 format
Hook up your Sony PSP to your computer via a USB cable. Turn on the PSP and put it in "USB CONNECT" mode (it should display the words "USB CONNECT" on the PSP display during the entire time you're transferring files, and plug it in if you don't have a fully charged battery).
If your computer complains that you are connecting a high-speed USB device on a low-speed USB port, try unplugging it (which is to say, take your PSP out of "USB CONNECT" mode, then unplug the cable from the PSP) and plugging it into a different USB port. Somewhere on your computer you have a higher-speed port, which you should certainly use if you can. If not, or if you can't figure out which port is USB 2.0, then you should be able to safely ignore the warning message and proceed anyway. Once you rehook up your PSP, do make sure you remember to put it back into "USB CONNECT" mode).
Your PC or Mac should just magically show a new removable hard disk on the desktop (or, if needed, go to My Computer to find it). On a Mac it'll probably show up as a device called "Removable Drive", but on a PC it can show up as drive E:, F:, G: or whatever else is the next available drive name on your computer. If it doesn't show up and you're running Windows XP, then you might need to search for the proper driver, which is hopefully an option. If you're running an earlier version of Windows, you're kinda on your own because earlier versions don't support pluggable hard drives. There's an untested Windows98 driver you can download from Interia.pl, but I haven't heard from anyone whether it actually works or not.
Once your PSP shows up on your computer, you should be able to navigate the different directories to find a folder called MUSIC. That's where you want to drag and drop your MP3 files, so do so now, realizing that each music file typically takes up 2-3MB of space, so the default 32MB Memory Stick Duo that came with the Sony PSP is only going to be able to hold about one CD of music before it's full, and that's assuming you don't have any game saves on it. Instead, you might consider buying a bigger Memory Stick: I have a 512MB one that gives me plenty of space and it didn't cost much (Amazon.com, for example, sells this funky green 512MB PSP-compatible Memory Stick for less than $40, with free shipping).
(If you don't have a "MUSIC" folder on your PSP then you might need to have the PSP unit itself reformat the memory stick (rather than your PC) so that all of the folders are setup properly.)
Once you've copied your music files onto your Sony PSP device, you should be done. Take the PSP out of "USB CONNECT" mode, then unplug the cables, hook up headphones so you can hear the PSP audio, and then go to the MUSIC area on the PSP.
One of the items listed in "MUSIC" is something called Memory Stick. Your songs are in that folder. To get to them, move the highlight bar to "Memory Stick" and press the "X" button:
You can see the "X button on this photo: it's the lowest of the four buttons on the right side control area.
You should then move into the Memory Stick music area and see all of your MP3 files. Click on one to play it!
Hopefully these detailed instructions will help you avoid tossing your PSP out the window. If not, well, let me know when you'll be tossing it and maybe I can catch it and use it as another test device. :-)
Please Rate Me if this Helps
Apr 15, 2009 | Sony PlayStation Portable (PSP) Console
PSP USB Mode
make sure a memory card is inserted when you plug the PSP in.
$ony was retarded and didnt build in any internal memory on the PSP =/
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
Sync music to psp
  • Hook USB cable between the PSP and PC
  • On the PSP under Settings, select USB connection
  • Your Vista PC should recognize that the PSP is connected. The PSP should be displaying "USB Mode".
  • On the PC add music to the removable drive that represents your PSP memory stick. Put the music in the Music Folder.
Jan 23, 2008 | Sony PlayStation Portable (PSP) Console
Help me with my psp please
Hook up a USB cable between the PSP and your PC. Turn on the PSP, Scroll over to Toolbox, and move up one notch to USB and press the X button, The PSP screen will tell you its in USB mode.
If your running Windows XP, or Vista on your PC, the PC should recoognize and ask you what you want to do. Select open a Folder. Once the Folder opens on your PC, you can move files to and From the PSP.
Jan 19, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
150 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
