Question about Micro Innovations KB985W Keyboard
When i type in my email it doesnt type in the dot symbol only the > symbol< and also when i try to type the number it only types the symbol please help
  • 390 Answers
Hi
one of the shift keys is stuck try removing them and replacing them back should help
hope this helped
cheers
pls rate the solution if it was any help
Posted on Jun 28, 2009
Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings > Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
Mar 21, 2018 | Kyocera Cell Phones
What is the code to unlock a blackberry curve 8520
Hello. you can get the accurate unlock code for your Blackberry 8520 Curve from Mobile-Unlocker.com at affordable cost with an easy unlocking guide. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold ?ALT? key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry 8520 Curve will now be unlocked.
Jan 08, 2015 | RIM Cell Phones
What are the restrictions codes of nokia x3-02
The restriction code for a mobile phone is unique and it is based upon the IMEI number of the device. You can get the unique restriction code for your Nokia X3-02 from ClassicUnlocking.com at affordable cost.
1 - Switch on your Nokia X3-02 Type without any sim card.
2 - Don't bother as to what is displayed on your Nokia X3-02 Type.
3 - Compose #pw+CODE+1#.
4 - The Nokia X3-02 Type would then display the message "SIM Restriction Off" and will be unlocked!
Jul 01, 2014 | Cell Phones
I need a code of a simple login form with the output
<?php
require("db/config.php");
session_start();
if(isset($_POST["btnLogin"]))
$nm=$_POST["txtUid"];
$pas=$_POST["txtPass"];
$q=mysql_query("select * from userinformationtb where user_id='$nm' and password='$pas'");
$data=mysql_fetch_array($q);
$_SESSION["seid"]=$data["user_id"];
// session_id();
if($nm==$_SESSION["seid"])
header("location:php/home.php");
//echo "valid";
else
echo "invalid";
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Untitled Document</title>
<link href="../css/style.css" rel="stylesheet" type="text/css" />
type="text/javascript" src="js/script.js">
type="text/javascript" src="js/cufon-yui.js">
type="text/javascript" src="js/arial.js">
type="text/javascript" src="js/cuf_run.js">
<link rel="stylesheet" href="css/validationEngine.jquery.css" type="text/css"/>
src="js/jquery-1.8.2.min.js" type="text/javascript">
src="js/jquery.validationEngine-en.js" type="text/javascript" charset="utf-8">
src="js/jquery.validationEngine.js" type="text/javascript" charset="utf-8">
jQuery(document).ready(function(){
// binds form submission and fields to the validation engine
jQuery("#frmLogin").validationEngine();
</head>
<body>
<form id="frmLogin" name="frmLogin" method="post" action="">
<table width="548" border="0" id="txtbrder">
<tr>
<td width="90" height="">Enter User Id </td>
<td width="152"><label>
<input name="txtUid" type="text" id="txtUid" class="tnm validate[required,custom[email]] text-input" />
</label></td>
<td width="56"><div align="left">Password</div></td>
<td width="154"><label>
<input name="txtPass" type="password" id="txtPass" class=" tnm validate[required] text-input validate[required,minSize[6]] text-input" />
</label></td>
<td width="74"><label>
<input name="btnLogin" type="submit" id="btnLogin" value="LogIn" style="background:#0000FF;color:#fff;"/>
</label></td>
</tr>
</table>
<a href="php/userinfo.php">Create New Account</a> &nbsp;&nbsp;&nbsp;&nbsp;
<a href="php/forgotpassword.php"> Forgot Password ?</a>
</form>
</div>
</body>
</html>
Oct 31, 2013 | Computers & Internet
I cannot send attachments or email from yahoo. I have run virus and spyware programs. When I try to reply or forward this message comes up. &lt;html&gt; &lt;head&gt; ...
Try downloading IE8, Also I Suggest Update your Adobe Flash Player and Java script to clear your
cache, cookies, and browsing history. If all eles fale's try using yahoo classic email. Please rate my answer. Best of luck to you.
Jan 31, 2011 | Yahoo Mail
I have an asus eee netbook that is less than a year old&gt; i have a problem with the keypad.Everytime i type in numbers, fullstops or comma and so on&lt; i get the symbols instead of the...
> less than one year old
Then, the WARRANTY for it is still valid, and any problems will be fixed by ASUS, at minimal cost to you.
However, are you sure that you are not pressing the 'NUM LOCK' button.
When 'NUM LOCK' is active, then pressing the keys gives the numbers.
When 'NUM LOCK' is NOT active, then pressing the keys initiates the actions (left-cursor, PageUp, et cetera).
Jan 30, 2011 | ASUS Eee 900 Netbook
How do you get to type the @ function on the keyboard, when there are 4 functions that you can get from that key - I keep getting a 2 when I want to type my email address on my new laptop.
Just hold <Shift> and then press the <2> key at the upper-right of the keyboard. Do the same with <!>, <#>, <$>, <%>, <^>, <&>, <*>, <(>, <)>, <_>, <+>.
Go to this link and download the manual of your model 5920
Dec 27, 2010 | Acer Aspire 5920-6727 Notebook
This the messagethat got Content-Type: text/plain; charset=iso-8859-1 Content-Transfer-Encoding: quoted-printable I'm trying=A0 to connect with you for a very long time, why don't you call = me or...
That is and HTML message that may not have been assembled correctly by the sender or corrupted during transmission and reception. That is not rare.
Nov 06, 2009 | Yahoo Mail
Micro Innovations KB985W Keyboard Logo
103 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
