Question about Vtech V.Smile Pocket
I cannot get the V-smitl pocket to power up. I have put brand new batteries in it, I plugged it into the car car charger, no luck. I cannot get it to do anything. Please help.
I did two things for my son's cyber pocket - first I took the batteries out and pressed the buttons inside the battery area for over a minute - put the batteries back in and it didn't work. Took them out again and pressed the on button for over a minute and then put the batteries back in and it worked again. hope this helps
Posted on Aug 04, 2009
  • RogersStacy7 Sep 14, 2010
    Wow that really worked thank you
  • demetrius lambert Jun 20, 2013
    where is on btton
How do you charge a razor pocket mini motorcycle
You use the supplied charger, or if you got it used without a charger, you can buy one here: Replacement Razor Pocket Rocket PR200 Scooter Battery Charger Adapter... After that, you plug the charger into the wall securely, and pull down on the round cover next to the motorcycles power button until it opens. Then plug the other end of the charger into the motorcycle.
Jun 21, 2014 | Electric Razor Pocket Rocket Ride-on...
I just bought a battery charger, plugged it in and its not charging
I suggest to you to buy a new battery for you HP iPAQ H4150 Pocket PC and see if that charger will charge it up. If the new battery does charge then the problem was with the old battery.
If it doesn't charge up on the new battery then, your problem lies with the battery charger. You should check that the voltage of the battery charger is compatible to charge the voltage of the battery.
Hope I have been of assistance to you,
Cheers :)
Apr 24, 2010 | HP iPAQ H4150 Pocket PC
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Brand mew makita set batries are flashing as if they were broken
Hi, How are they when you put them in the drill? Are they dead to the point of needing a charge or do they have plenty of power? If they have power in the batteries, and you go to recharge them and the charger is indicating the batteries are faulty, I would say that it is the charger that has the fault not the new batteries. Try and charge them anyway and see if they take a charge. If not, take the new batteries back to where you bought them and tell them they will not take a charge and they are new. Have them pull out a charger and see what happens. If they start to charge, you will know the problem is you're charger. Good Luck.
Shastalaker7
Jan 31, 2010 | Drills
My battery wont charge and its brand new
Did you put the battery into the charger in the correct way? Is charger plug into outlet that has electrical power "ON"?
Jun 30, 2009 | Porter Cable 19.2V Drill/Driver
When charging my axim X30 on the cradle, the on-off light is blinking from green light to amber consistantly... when I remove the device from cradle the device does not turn on at all.. I have replaced the...
It sounds to me that your "original" battery, the one that causes the blinking when charging is completly drained dead, causing it to show an error by blinking the light.
I have one of these PDA's and have never had that problem, I also have a larger battery as well, and it works great. I suggest recycling the other battery, and possibly purchasing another larger one for back up,
Mar 27, 2009 | Dell Axim X30 Pocket PC
My imate Jam wont powerup
Just put the charger in the device and then soft reset it light will turn to yellow. if this dosent work try to put the charger and then remove the battery and put it back to phone while the charger need to be remain connected.this is gonna work
cheers
Mar 05, 2008 | i-mate JAM Pocket PC
Vtech V.Smile Pocket Logo
1,431 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
relojmesa
Are you a Vtech Toy Expert? Answer questions, earn points and help others
