Question about Little Tikes Yamaha Rhino 660 Ride on Car
Can't find connector to charge battery
We have the Yamaha Rhino 660 and need to charge the battery. We cannot find the connector to hook it up to the battery charger.
  • kkinate Jun 29, 2009
    We looked evverywhere for the connector. We found the compartment where the battery is located, but cannot find the piece you connect to the charger at all. I thought it would be where the battery is and we would just attach it to the charger, but there is nothing like that anywhere,
  • 1,555 Answers
I need to know a bit deeply about your problem. From your question it seems that your connection is broken and now you are unable to charge your battery if it is such then kindly let me know what type of solution you want from me you need to replace the whole kit or just a quick fix for this problem and kindly let me know the exact damage caused to the connector. wether + side is damaged or - side is damaged.
Posted on Jun 28, 2009
  • 2 more comments
  • Aruna Singh
    Aruna Singh Jun 28, 2009
    This is a site which is dedicated to your bikes battery problems which I'd like you to check out
    http://www.rhinoforums.net/lighting-ster...
    If just your + or negetive is broken then try this
    one of the contact that connect the (+) of one battery to the (-) of the next battery broke. If that's what happened, no worries, you'll be fixed in no time.
    Find yourself a penlight, remote or any other device that uses AA batteries that you aren't going to miss.
    Open up the battery compartment and remove one of the spring contacts.
    You may have to hunt around to find something similar, but all it has to do is fit in and make contact.
    The compartment cover will hold the batteries in.
    If this also don't solves your problem I'm always here. Thank you for visiting fixya kindly rate my solution.
  • Aruna Singh
    Aruna Singh Jun 29, 2009
    Okay I will look out for a circuit diagram for you. If can't get then I'll have to draw one for you.
  • Aruna Singh
    Sir,
    Rhino is offering electrical diagram for your model at the undermentioned link below. Here you can log in get the diagram and connect the 3 wires to the batteries as indicated in the circuit diagram.
    Getting a membership out there would be good for future troubles also.
    http://www.rhinotalk.net/forums/yamaha-r...
  • Aruna Singh
    The registration out there is completely free and easy. If after that also you are unable to connect your batteries kindly do revert back to me at any hour.
Does the ECU on a 2007 Yamaha Rhino 660 control the governor?
Hi, Paul for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Speed Governor
how do get rid of speed limider
Yamaha 2004 Rhino 660 YXR660FAS Service Manual
OEM parts for Yamaha
Yamaha RHINO 660 Owner Manual
Jan 18, 2017 | Yamaha Motorcycles
Yamaha rhino problems
It could be your battery not being fully charged or possibly dirty fuel.
Aug 07, 2014 | Yamaha 2005 Rhino 660 Auto 4x4
Yamaha 660 WHAT KIND OF OIL DO I NEED FOR MY 660 YAMAHA RHINO
Semi-synthetic or Mineral oil, Don't use fully synthetic, it can make the cluch slip.
Jun 17, 2013 | Yamaha 2005 Rhino 660 Auto 4x4
Yamaha rhino electric batery is charged but motor doesent go
have you verified that the battery is charged using a multimeter?
May 14, 2012 | Little Tikes Yamaha Rhino 660 Ride on Car
2007 Yamaha Rhino 660 dies and pops the 30amp fuse on Relay
I would carefully go over your wiring, especially any you may have disconnected during the head gasket swap, and check for a loose ground first.
If all your connections are good, then take a voltmeter to your battery, see what it's putting out. (If you can load test it, even better). Sometimes, when a battery get's messed up, it'll start overloading and put out too much power, and burn up fuses/wires.
Dec 29, 2009 | 2007 Yamaha XT 660 X
HOW TO STRAIGHTEN A BENT YAMAHA RHINO FRAME
I would think that it would be cheaper just replacing the parts that need replacing and bill your friend for it later
Aug 21, 2009 | 2008 Yamaha XT 660 Z Tenere
Little Tikes Yamaha Rhino 660 Ride on Car Logo
111 people viewed this question
Top Little Tikes Toys Experts
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
