Dear
The error occurs in accessing to the counter memory PCB.
Disconnect, clean and connect the counter memory PCB,
or replace it.
If problem persists replace the main controller PCB (Main).
Error
Code Detail
Code Error Name/Explanation of Error
E000
0000 The
reading of the main thermistor does not reach 30°C 1 sec after the main power
switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000 The main
thermistor detects 250°C or higher.
0001 The main
thermistor or the sub thermistor detects overheating (hardware circuit
detection).
0002 The sub
thermistor detects about 295°C or higher.
E002
0000 The
temperature of the fixing film is as follows: ·has exceeded 100°C, but does not reach
115°C within 1 sec thereafter. ·has exceeded 140°C, but does not reach
150°C within 1 sec thereafter. ·has exceeded 160°C, but does not reach
165°C within 1 sec thereafter.
E003
0000 The main
thermistor reading is lower than 140°C when paper is moved.
0001 Low
fixing temperature detection after standby (by sub thermistor)
E007
0000 An error
in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
E010
0000 After the
main motor drive signal is generated, the clock signal does to arrive within
1.3 sec.
E014
000 After the
fixing motor drive signal is generated, the clock signal does not arrive
within 1.3 sec.
E019
0000 The waste
toner case is full of waste toner.
E032
0001 The DA
unit connection is disconnected (after connection).
E051
0000 At
start-up, home position is not detected when the horizontal registration
assembly is moved 100 mm in the direction of home position.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Обычная таблица";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
E000
0000 The
E001
0000 The main
0001 The main
detection).
0002 The sub
E002
0000 The
E003
0000 The main
0001 Low
E007
0000 An error
E010
0000 After the
1.3 sec.
Hi, yes it is drum RELATED error, but before changeing the drum, clean the drum sensor. When you remove drum unit, inside of copier in drum unit place, from left side, uperr in the middle you have small sensor - Clean it!
Then try again.
If not tell me the exact error code eg. E 020 - 01A2 or?
The wiring is faulty,short circuit or open circuit.The hard disk drive is faulty or the main controller board is faulty.For reset press: Copier-Display-Jam/Err.
you need to clear thepassword in this order touch ADD FUNC key then the 2 and 8 keys together then touch ADD FUNC key again lcd screen should change touch copier then function then clear then pwd then ok then yellow reset 3 times that should do it
hi..there...you may visit canon website at internet..chose product support/dowlnload----find your product here and finally you can get and download manual book as pdf for free....good luck..
