Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Safety Shut Off Cord Keeps Messing Up
When I try to start my mower, the safety shut off cable will not allow me to.
I can start it and cut but when I shut it off, it will not start again. It is the cable
and I think there should be a solution but I can not figure it out. It seems to
be stretched out and will not pull back enough to start.
Anyone interesting in helping a woman with this problem? I can usually
figure things out but this has me stumped.
Thanks,
rwvanlue
  • 486 Answers
SOURCE: the pull cord broke I just can figure out how to
1) Remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope.
This is the area that causes so many guys a lot of extra trouble!
2) Locate the string that is left and the hole it is threaded thru
3) Determine how much string has broken off of the rope that came out
*Note: if more than 1 inch is left, then the rope needs to be replaced
4) Obtained a length of rope appropriate for your engine, it is always better to have too much rope.
You can always shorten if it is too long.
Make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) Wind the rotor in the direction of what the rope would pull,
(this will tighten the spring) until the spring is completely wound.
Remove 1/2 to 1 revolution.
6) Install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
Tie a knot in the end of the rope, leaving a 3/8" tail free.
Then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
9) When the unit is functioning proplerly, re-install housing onto engine.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Dec 04, 2009
Testimonial: "Thanks I think I know what to do."
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
  • 420 Answers
SOURCE: MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Posted on Jun 04, 2010
mikehowy
  • 177 Answers
SOURCE: When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Posted on Jun 18, 2010
  • 100 Answers
SOURCE: Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Posted on Aug 14, 2010
I was cutting grass on my husky zero turn shut it off to move limbs got back on engine will turn over but want start any suggestions
something has operated a safety switch
check the procedure for hand brake , foot brake , seat , cutter operation , gear selection or any item that uses a safety switch to allow it to start
Mar 24, 2016 | Garden
It starts and runs but when when I put the cutting in gear it dies. It's supposed to do this if the mower is in reverse but now it does it when going forward.
Does your mower have a safety reverse mowing switch built in on your key switch? If so it must be set to allow reversing while the blades are engaged..it will shut it down if not set to the proper position..if it does not have one..most likely you have a bad seat safety switch..try TEMPORARY bypassing it with a jumper wire..if it works the switch needs replaced.. Good luck
Sep 03, 2015 | Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
May 29, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Blades will not shut off if i try cutting in reverse without turning on the reverse pus button.keeps shorting out pto button
what Model Cub?
All the Safety controls pass through the PTO Switch on many of the older Tractors.
Sep 27, 2013 | Cub Cadet Garden
My riding mower stopped as if the spark had been cut off. I tried to start it and absolutely nothing happened, Could the alternator be bad and it shut off the engine once the battery drained?
Probably not. The machine doesn't need alternator to run the mag fires the ignition, the alternator only replaces juice the battery used to start it. Eigther ignition unit failed or one of the safety switches. If I had to bet, my money is on safety switches.
Sep 29, 2010 | Troy Garden
The safety switch on my clutch keeps messing up and I can't start my JD L118. I understand there are 4 wires on this switch. Can I bypass this switch?
you may want to consider replacing the switch. These safety switches serve a very important function. They protect YOU.
I don't believe in bypassing any safety device on a mower, to many feet have been lost.
Sep 23, 2010 | Garden
When i let go of the operator presents bar the mower took a minute to shut off ..now it wont start.
Sounds as if the safety cable is sticking. The reason it won't start is because the brake that shuts it off is still pressed against the flywheel. Try lubricating the safety cable.
Jim
Oct 24, 2009 | Toro Lawn Mower With Toro Power Tools
Suddenly stopped then could not pull mower backwards because rear wheels would only go forwards, and mower would no longer start
Sounds like your mower has a safety mechanism that has locked up. On your push handle is a bar that must be pulled back in order to pull start cord, it has a cable that goes to the safety brake, check the cable to the safety brake on the flywheel, it may be broke. If it isn't in the safety brake itself, try spraying the cable with WD-40 as this may free it up. Or the cable may need replacing from wear. To check this pull back on the handle and watch the on the side of the engine where this cable attaches, if it is moving on the side of the engine then this cable won't be the problem. In this case it most likely will be the safety brake itself that's the problem. Do not remove the safety brake if under warranty as this will void your warranty.
Aug 08, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
RE: SEARS SELF PROPELLED LAWN MOWER 917.374750..WHEN PULLING THE CORD TO START THE MOWER ( AS USUALLY IS DONE ) THE CORD FAILS TO MOVE. CKED THE UNDERSIDE FOR POSSIBLE OBSTRUCTIONS & FOUND NONE.
Most lawnmowers manufactured over the past 15 years have a safety lever that needs to be pulled in to allow the mower to be started. This lever is normally located near the handrail and acts as a failsafe that shuts down the mower if you were to trip or release it . The intent is to protect you from injury if you let go of the handlebar. make sure you've puled in the safety lever before pulling on the cord .. otherwise, it shouldn't budge.. Hope this helps..
Sep 22, 2008 | Washing Machines
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
102 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
