Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Where is the defrost fan in FFa70S freezer - Hotpoint FFA70 Bottom Freezer Refrigerator
  • Hotpoint Master
  • 4,655 Answers
Please double check your model number. I cannot seem to find that model.
Posted on Jun 28, 2009
  • John Tripp
    John Tripp Jun 29, 2009
    A defrost heater is always below the evaporator coil inside the freezer compartment.
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
I have a sub zero 361rfd. The freezer portion is no longer cooling, however the fan still runs. Also, The refrigerator is set to the coolest temperature but I suspect it's not sufficiently cold....
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Aug 18, 2011 | Refrigerators
Freezer not cold.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
Red warning light on lowtemp display,freezer defrost warning on freezer display .freezer is not working.hotpoint/FFA70S.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 20, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Danby DFF8803W freezer keeps freezing up. What causes this?
Some models are a manual defrost. That meant every 3-4 weeks you must unplug it and let it defrost. These types usually have no fan in the freezer, instead it's a cold plate. If there is a fan in your freezer section it should automatically defrost. You might have a bad defrost clock, or a bad defrost heater.
Nov 02, 2009 | Danby DFF8803 Top Freezer Refrigerator
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
98 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
