check the belt on the side of beater brush take out screws in the bottom lift up plate and check the belt it either to loose or to tight or broke. You have to replace them every so offend.
I tried everything and this is what solved the problem of the brush not turning and no suction on the brush area. I took off the lid where the roller brush is and cleaned the sided of the roller brush, it was frozen tightly from HAIR. Used a small knife to get it all. AI pulled out all that hair and now it works!! yay!!
Was this helpful?
Yes
No
Popular Solutions for Eureka 5893AVZ Bagless Upright
eureka 5893avz 4d vacuum brush motor will not run. Push reset botton doesn't start. where can I get...
(More)
eureka 5893avz 4d vacuum brush motor will not run. Push reset botton doesn't start. where can I get a motor. brianmiller321@sbcglobal.net Thank you
Okay, what happened is I was vacuuming one day and something must have been sucked into the vacuum...
(More)
Okay, what happened is I was vacuuming one day and something must have been sucked into the vacuum that did not belong. I proceeded to turn it off and remove the obstruction. I found nothing out of the ordinary so I reassembled it and turned it back on. This time I smelled something burning so I turned it off again quickly and opened it back up to see what the problem was. I still saw nothing out of the ordinary. Now the brushroller will not work at all. The vacuum still has sucking power. In fact everything else works but the roller. I have taken it out and cleaned it thoroughly and I checked the belt which still seems to be in perfect condition. The motor for the brushroller seems to be the problem. I have no clue on how to go about fixing it. When I put the vacuum in Carpet mode it seems that the motor for the roller just ignores it. And for whatever reason I can't find a website that can tell me about how much another motor would cost. If I can avoid spending any extra money that would be fantastic. I am just stuck in this situation and if anyone can offer any advice at all I would greatly appreciate it.
