Question about Singer 7436 - INGENUITY
When I go to wind the bobbin the needle still moves up and down and it will not wind the bobbin but stop beep and flash. The bobbin is as far to the right as it can go but it still is not winding.
    Problem Solver:
  • 6 Answers
Make sure that you are pushing the bobbin winder to the right and that it is clicking in place once you put the bobbin case on the spindle, if the the little plastic piece to the right that stops the bobbin when it is full is too close it will not allow the spindle to catch the mechanism to "wind the bobbin". Loosen the screw and turn it away from the spindle then try again. That's all I've got, hope it helps, this happened to me on my first machine...
Posted on Nov 06, 2009
  • 136 Answers
Take it to repair shop, getting to the problem requires taking the shell cover off the machine, difficult to do, then fixing the problem might be electronic in nature.
Posted on Jul 04, 2009
Trying to rewind bobbin machine starts beeping and stops
Is the bobbin pushed over to engage the stop
Oct 01, 2017 | Sewing Machines
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
Wind bobbin frister rossman 420
Hi - if I understand your questions you're trying to wind a bobbin on the top, and haven't got as far as sewing yet.
To do this you usually have to put the bobbin on the top spool for it, and move that into position so that it turns.
To disengage the needle so it doesn't go up and down whilst you wind the bobbin up, on most machines you have part of the main drive wheel (on the far right) which turns against the rest of it, disengaging the part of the drive which powers the needle going up and down.
Or at least that's how it works on most machines.
Jan 28, 2013 | Sewing Machines
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
Needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
Apr 06, 2009 | Singer 7436 - INGENUITY
Singer 7444 won't wind the bobbin... please help...
I guess the machine was defective, i trade it to the new one, and the bobbin worked fine...
Dec 26, 2008 | Singer 7444 Mechanical Sewing Machine
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Singer 7436 - INGENUITY Logo
310 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
