Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
My krystal clear 636 pump sounds like its working but no water being pumped back into pool, any ideas my pump actually says model#636 on the side
  • 93 Answers
IF WATER IS NOT TURNING IN PUMP BASKET IT IS YOUR IMPELLER AS THIS IS A COMMON PIECE THAT BREAKS ON THESE PUMPS MAKE SURE YOU HAVE ALL CONNECTIONS TIGHT AND ALL VALVES ARE OPEN TRY TAKING RETURN HOSE OFF THE POOL AND START TO SEE IF YOU GET FLOW YOU WILL HAVE TO PUT A PLUG IN RETURN SO WATER DOESNT LEAK OUT
Posted on Jun 30, 2009
Can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Apr 11, 2012 | Pool & Spa
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Jul 16, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Pump running no water flow
you have an air leak on suction side make sure all connections are tight as well as strainer top
Jun 23, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Water not flowing out of pump
Have you primed the pump by bringing water down to the pump? It will not work if the supply line is not filled with water from the pool.
Jun 20, 2009 | Intex Krystal Clear Model 635 Pool Filter...
My pool pump stopped working
It probably has air in it. Loosen the plastic plug on the top until water runs out of it steadily Then close the plug and turn it back on. That should do it!
May 17, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Mar 15, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
1,217 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
