Question about Hotpoint Refrigerators
I have a hotpoint refrigerator model CSX24XJ that was leaking water out the freezer door. I found that the drain was clogged and fixed this but I cannot find the drip tray. Does this model have a drip tray and if not where does the water in the drip tube go?
  • Hotpoint Master
  • 4,655 Answers
There is a leak somewhere in your defrost drain. Most times this is caused by a blockage near the area of the leakage. Below is a link to a very informative way to help you resolve the problem. Thanks.
http://appliancejunk.com/forums/index.php?topic=22.0
Yes your model has 2 drip trays. 1 is below the evaporator inside the freezer and behind the back wall covering the evaporator. The other is below the refrigerator next to the compressor where the condenser fan heats the water and returns it back to the air inside your home. Thanks, Sea Breeze
Posted on Jun 28, 2009
Hotpoint CSX22GR side by side refrigerator / freezer. Ice in bottom of freezer and water leaking on floor on freezer side. How do I find the problem??
The problem is the defrost drain is clogged, the drain is located on the lower part of the back panel and can be gotten to be removing the drawers and to clear drain push a wire hanger through it till small hole delvolopes then flush w/hot water till completly clear
Jul 25, 2011 | Hotpoint Refrigerators
Water leaking from the bottem of double door refrigerator
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Aug 27, 2010 | Hotpoint HSS25GFP Side by Side...
My Hotpoint refrigerator is leaking puddles of water inside my vegtable crisper and on the floor, what can I do ?
It is most likely due to a clogged defrost drain. I put together some instructions on cleaning the drain, follow the link below and let me know if it was helpful.
Drain Leak
May 22, 2010 | GE Hotpoint Top-Freezer Refrigerator
Leak
Sounds like you have a clogged drain the water freezes melts during defrost. You have to take the freezer floor out. to clean the drain.
Apr 27, 2010 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Bottom freezer keeps leaking
check your pan under the fridge and see if its dry. Your drain may be clogged. and the water is comming out the door during defrost. paper and food particles clog it.
Apr 26, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Hotpoint csx22d side by side has leak under freezer side @ door...coming from wiring harness that runs up into bottom of freezer maybe??????
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Sep 16, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Open Questions:
Refrigerators Logo
351 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
