Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
WD-52327 Lamp hour indicator.
I had a technician come and replace my lamp and he was able to check how many hours I had on the lamp. But he wouldn't tell me the service code. I know he pressed the menu button and then entered some numbers. Does anyone know the service codes for my tv?
  • T New Nov 08, 2007
    Thanks. menu 5-7-7-0 is the code for the lamp hours. The first time I entered the code it pulled up some stuff I didn't understand. So backed out and did it again, and menu 5-7-7-0 worked. Thanks again.
  • 363 Answers
Found this in another forum. So apologies if there are any innacuracies. service code
Press the "AUDIO" button on a remote hand unit to select an adjustment function.
Press the ?VIDEO? button to select a specific adjustment Item.
After selecting an adjustment Item, use the ?ADJUST UP/DOWN? buttons to change data.
? Press ?ADJUST DOWN? to decrease the data value.
? Press ?ADJUST UP? to increase the data value.
Press ?ENTER? to save adjustment data in memory. The character display turns red for approximately one second in this step.
Press the ?MENU? button on the remote hand unit twice to terminate the adjustment mode.
options code
Posted on Nov 07, 2007
  • Martin B
    Martin B Nov 07, 2007
    Ah there is a different code to get the lamp hours ..
    MENU, 2,4,7,0
    Hope that's solved!
  • Charles Tilley Apr 03, 2011
    I tried this number. I had to press menu, Enter , move to Global and enter 2470. Mine showed over 16000 hours. Man, if that is right, I may be setting a record.
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010
Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life.
Mar 17, 2015 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi wd-60735 no picture and red lamp light stays on
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Oct 07, 2011 | Mitsubishi WD-60735 Projection Television
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
Jul 26, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Do i need to buy the bulb housing for a WD-52327 or just the bulb?
You can do either, it's your choice. A lamp only replacement will save you a bit of money, but the installation will take just a little while longer. You will need to remove the old lamp from the housing and transfer the lamp connector to the new lamp. You should use either gloves for this procedure or at a minimum use a paper towel to handle the lamp. WASH YOUR HANDS BEFORE AND AFTER... these lamps contain Mercury.
Mar 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
How to reset hours (4000) after replacing lamp
when you replace the lamp as soon as you power up the set it should automatically bring up the menu asking if you have replaced the lamp and would you like to resett the lamp hrs. Your problem is not with the lamp. its most likely the power pwb capacitors. You can get the repair kit at the following link with instructions.
Sep 25, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
854 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
