Question about Coleman Electrical Supplies
The generator runs fine but will not give us any powere
  • 25 Answers
Hello, Has this generator been setting for awhile or was it in use when the power ever came back on? Have you tried to repolarize it? To do this , Shut off the generator and unplug any cords or wiring from unit. Take a electrical cord that has a plug on one end and seperate the wires on the other end of cord. Strip the ends of the wire back about half an inch on each seperated wire.Plug the Male end of the wire into one of the 110V recepticles. Connect one of the ends of the wire you stripped back to the positive side of a 12 volt battery. Now with the other end of the wire you stripped back touch it to the Negative side of the battery for 1 sec and remove it. Unplug the wire from the recepticle and battery. Fire up the Generator and check the voltage! This repolarizes the unit and fixes most non generating problems from Non use and back feeding! Hope that helped! Rick
Posted on Jul 02, 2009
    President:
  • 1,723 Answers
Check the voltage regulator. Inspect for any burned spots or a blown fuse.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 30, 2009
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
Posted on Dec 05, 2008
  • 384 Answers
SOURCE: Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Posted on Jul 01, 2009
  • 2976 Answers
SOURCE: My generator starts but not give 220 volts power
Check the voltage regulator and any fuses or breakers.
I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
All Power America APG3535CN, 2800 Running Watts/3500 ...
www.amazon.com/...Power...Generator/.../B000U0OJ...
Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
NIKOTA 3500 WATT GENERATOR - YouTube
? 0:58
https://www.youtube.com/watch?v=NEeu9Y-0_KM
Aug 27, 2011 - Uploaded by mamasboypowersports
NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
I have a nikota 3500 watt generator and I am not getting any ...
www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
Generator outputs low variable voltage, ideas for troubleshooting ...
www.smokstak.com > ... > Generators & Motors General Discussion
Jan 20, 2016 | Electrical Supplies
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
It starts and runs fine If you shut it off you hav to wait about 30 mis before it will start back up
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/
Generator Guru
Sep 23, 2015 | Honda 3000 Watt Portable Generator
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
Have a gg3500 gas generator that give no current
you need to check to make sure you have no power out put, check all receptacle. if none check your owner Manuel on how to flash your unit. you may want to check all breakers. if flashing don't work take it to repair center to check stator and rotor
Oct 03, 2009 | Electrical Supplies
I have a brushless Genpower 5250 generator, it still fires up fine, but creates no voltage. As a gift we were given a 5600 Sears generator yesterday, and when i plugged in the plug for the pump to test it...
It's very possible that the cord is bad (shorted) causing a fault on the generator. I don't think it's fried or anything. Probably just tripped something. Give it a good look over.
Jul 10, 2009 | Electrical Supplies
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Check out our testing video!
We hold parts too!
Oct 05, 2008 | Electrical Supplies
Electrical Supplies Logo
199 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
