Question about Ruud UAKA037 Air Conditioner
My ac was working until we had a big dust storm and it stopped cooling
  • old fart58 May 11, 2010
    What do you mean by working? Do the fans and compressor run when powered up? Do you mean it just does not produce and temperature drop?
    Scholar:
  • 70 Answers
Wash out outsde coil first also check breaker. If coil is full of dirt it will cause high head pressure and overheating, Can trip breaker or shut down compressor.
Posted on Jun 28, 2009
My ac unit doesn't blow out cold air but everything else works do you know what the problem could be,it's a standup one
Probably needs a recharge... should be able to get the kits at a hardware store..... unless it was. Blowing cool when you started it and then it quit a few hours later... if that is the case place it in the bath tub and let the ice from moisture build up ( around the cooling coils high humidity will cause water to form freeze and layer up until it renders the ac useless until completely thawed... takes about 2 hrs... lots of water may run out as it thaws, that is why I suggested the tub... ps. This will happen to every ac and is not a big deal just a pain... and no don't use a hair dryer on it or warm water unless you don't like your ac... just time.
Jun 22, 2015 | AC Cars & Trucks
Ffa52 hotpoint diamond freezer running too warm
change condenser fan clean condenser coil dust at bottom of ref stopping cooling processes.Just like if you put cardboard in front of your car it will over heat or if fan is not blowing air on condenser coil
will not cool it fan and coil at bottom of ref. remove back you will see the dust pet hair a big problem with ref.
Mar 04, 2015 | Hotpoint Refrigerators
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
Fan stopped working in my asus u20a
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 06, 2012 | ASUS Computers & Internet
MY SAMSUNG P35 LAPTOP STOP ITSELF ON BATERY AND AC POWER
This maybe heat problem.
Mar 27, 2012 | Samsung P35 HZM (NP35TP0FL2/SUK) PC...
SAMSUNG P35 LAPTOP
Mar 27, 2012 | Samsung P30 Notebook
Dell inspiron is turning off randomly
Sounds like overheating, daughter had same problem. Don't blow air thro cooling element on the back of the laptop, you'll blow any accumulated dust/fluff back into the fan, which will just blow back into the cooling element when the fan switches on or it'll stop the fan from rotating altogether. First turn it over and take the battery out, then remove the big L shaped cover from the bottom. There's a thick copper conductor leading to the cooling element' GENTLY lift the cooling element clear of the laptop base, using a soft brush remove any dust/fluff from the element. Then using canned air blow from the bottom of the laptop thro the fan to clear any dust/fluff. Once cleaned GENTLY push the cooling element into position and replace L shaped cover, replace battery and away you go. Daughters has been OK for a few weeks now, amazing how much fluff collects in those fans.
Hope this works! Gaz P
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Thermostat just stopped working.
is the tstat in cool mode? if not hit the mode button untill cool pops up then hit the down airow untill desired temp. sometimes the thermostat has a 5 min delay so be patent. If unit still does not run call the service co. and find out about how long they warranty their service call. usualy one month.
Jun 14, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Mar 19, 2009 | Refrigerators
Ruud UAKA037 Air Conditioner Logo
102 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
