Question about Evolis Pebble 3 ID Card Printer Package (P/N MIDS-E-SC)
Evolis Pebble 3 printer: the varnish is being put on as black
Help! I have three hours until a hugfe event that I need 25 more ID cards printed. The printing goes fine until the varnish phase: the varnish is being printed as black instead of clear; please help if you can.
    New Friend:
  • 54 Answers
Check if ribbon type is proper.
Do self adjustment at once.
Clean optical sensors emitting blue light just below you install ribbon in printer
Posted on Aug 29, 2009
  • allor79 Oct 18, 2010
    My ribbon was printing the varnish as black too. Ran a cleaner card through because I had just cleaned the gummy wheel with alcohol and thought it was a chemical reaction. When I looked at the ribbon I could see that the black panel before the varnish panel had been used by mistake. I had to roll the ribbon so when the optical sensor would view the clear varnish panel it was the real clear panel not the black panel.
Hi I got Evolis Pebble 4 and I have problem with printing the ribbon light is always ON and it does not print with YMCKO, but when I change to black ribbon K it prints. What is the problem.
It sounds like your ribbon setting in the printer-driver is set to the R2011 (or R2211) K ribbon. It should be set to R3011 for the full-color YMCKO ribbon. Check by locating the printer in the Windows Devices & Printers view (Win7: Start Button => Devices and Printers; WinXP: Start Button => Printers and Faxes). Locate your Pebble printer; right-click; select "Printing Preferences". Check your ribbon setting here and match to the ribbon that is loaded. NOTE that you can only make changes to this driver setting if you have Windows Admin rights with your Windows log-in ID. If you don't, have your systems administrator assist you with this by logging in with their ID.
May 04, 2015 | Evolis PEBBLE 4 Led Card Printer
Fault light showing hand is lit - what does this mean please ? Evolis Pebble 3 ID card printer
It means you need to insert a cleaning card for cleaning cycle of printer.
Open printer properties Click on Tools tab click on Printer self cleaning button. You will get a new dialog box asking to remove ribbon and cards and insert a cleaning card in feeder.
Insert a cleaning card in feeder . Adjust thickness pointer to maximum remove ribbon and just cleck to proceed for cleaning.
Mar 31, 2011 | Evolis Pebble 3 ID Card Printer Package...
My Evolis Pebble 3 ink ribbon breaks after I print 2 cards.
First clean Rollers and print head . Check if you have increased luminosity and contrast too much in printer Graphic properties. If this doesn't solves your problem increase x offset little bit using Px;+ command in Dialog with printer
Aug 04, 2010 | Evolis Pebble Color Card Printer
I have problem with my Evolis Dualys 3 printer printing a line on the card?
Your print head needs to be replaced if it a horizontal line
. Transport belt to be replaced if vertical line
May 06, 2010 | Evolis Pebble 3 ID Card Printer Package...
Evolis pebble 3 is printing very dark and then has large yellow and magenta spots
Check for luminosity and contrat settings in properties/graphic/more options
If you have replaced print head enter its serial number properly.
Apr 27, 2010 | Evolis Pebble 3 ID Card Printer Package...
On varnish the printing is break on 50% and stop?
You must check for
1. Varnish Sensitivity in Properties\Graphics tab it must not be too high
2. Check for steel plate on print hed if its alignment is proper or not
Mar 22, 2010 | Evolis Pebble 3 ID Card Printer Package...
Fading image...
1.Check for proper driver on evolis site.
2.Check whether both side printing is selected in driver
3.Check for Varnish sensitivity setting in Graphics setting it should be default.
4.Read the ribbon type with Rr command.
Feb 23, 2010 | Evolis Pebble 3 ID Card Printer Package...
My Evolis Pebble 3 says feeder error but there is not. It won't pick up a card when you try to print but when you press the push button it feeds out a card without printing. It will alos not print a test...
You must take following approach
1. There is a lever at feeder for thickness adjustment . Check it for proper thickness.
2. There is a hanging lever which acts as a card presence detector just where you place cards check if it is stuck and try to clean sensors aside it by blowing air .
3.Check if feeder motor is working by giving Mf;+ command
4.Check for proper ribbon setting.
5. Try downloading firmware which is available as an exe file for different models on Evolis site.
6. diagnostic software is also available on site.
7. You can also do self adjustment to adjust sensors.
Aug 16, 2009 | Evolis Pebble 3 ID Card Printer Package...
Evolis pebble 3 displays mechanical problem error?
Clean all rollers
Check if print head is mounted properly
May 27, 2009 | Evolis Pebble 3 ID Card Printer Package...
Evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
Evolis Pebble 3 ID Card Printer Package (P/N MIDS-E-SC) Logo
419 people viewed this question
Top Evolis Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
