Question about Mantis 4-Cycle Tiller
How do I check the oil on my Mantis Tiller with 4 stroke Honda Engine? THe manual that came with the tiller says it holds 3.4 oz of 4 cycle oil, but when I lay it on it's side the dip stick does not record any oil even when it is full. Because everyone thinks the oil should register on the dipstick too much oil has often been added. This leads to overfilling the crankcase to the point that oil runs out the air cleaner etc when the engine is operating.
  • 85 Answers
Tip the unit up with the front on the ground, the dip stick will be on the lower part of the engine & comming out at an angle
Posted on Aug 17, 2009
    New Friend:
I had the same problem. I laid my Mantis on its side and filled the crankcase to the top. When I tried to start it the oil came dripping out of the air cleaner housing and all over the grass big time. I re-read the instruction manual which CLEARLY states to rotate the Mantis forward on a level surface until it rests on its gas tank then fill the crankcase. I wish they would have put one of those triangle boxes with an exclamation point inside that said DO NOT LAY ON ITS SIDE AND FILL THE CRANKCASE! I bought this Mantis used so I own it now. As I watched the oil running out all over the place I was visualizing the big bill I was going to get from the lawnmower repair shop. WHEW! Thank God this Mantis came with the instruction manual or I may never have figured it out.
Posted on Jun 22, 2013
Mantis tiller won't start
Flush out old gas. Check/clean spark plug. Oil filled? Try spraying starter fluid in carb. Carb should not have any oil in it. Change air filter.
Jun 04, 2015 | Mantis Tiller Honda 4 Cycle - No Kickstand...
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
HOw can I find an owners manual for a GX Honda 4 stroke mantis.
You can check on this site for one, by entering the manufacturer and model number of the tiller. Make sure to enter the tiller manufacturer, not the engine,
http://lawnandgarden.manualsonline.com/manuals/device/tiller.html
May 27, 2011 | Mantis 4-Cycle Tiller
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
Four cycle mantis/honda engine gettting oil in carb and smokes
Honda GX25 GX35 manual on PDF.
http://www.smallenginewarehouse.com/images/manuals/GX25-35.pdf
May 26, 2010 | Mantis 4-Cycle Tiller
Where do you drain oil on honda gx25 mantis
jj505 has good and bad information.
Honda GX25 is a 4 stroke motor, with oil lubricated crankcase.
Oil drains out the filler.
Oil and gas do not mix on this four stroke.
The PDF below is the Honda manual.
Apr 12, 2009 | Mantis 4-Cycle Tiller
Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Mar 21, 2009 | Mantis 2-Cycle Tiller
Mantis 4-Cycle Tiller Logo
2,371 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
