Question about Intel Motherboard
Graphics problem i have a foxconn q965mc motherboard and the graphic does not display any red color can you help me
  • Anonymous Sep 15, 2008
    grahics problem
Posted on Sep 20, 2008
    Brigadier General:
  • 6,966 Answers
Most often, the symptom that you posted/described is not a graphics card problem nor a motherboard issue. Normally it is the vga cable that attaches the video card to the monitor.
The corrective procedure requires that the cable be replaced. A temporary workaround that you can try is to move the end cable (nearer to the video card) and twist it left/right, up/down and determine at angle/point the red will reappear.
Of course you can confirm/verify by temporarily connecting a known good monitor to your PC.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 07, 2007
After instal of pci-e graphics card it goes into reboot cycle??
Hi Paul, try to pullout the card and used on-board graphics. if it works without rebooting, the cards need to be replace.
Jan 10, 2014 | Foxconn G31MX-K socket LGA775 motherboard
Can foxconn 661m03 handle ati radeon 4650 agp?
Hello here is the foxconn homepage:
The graphic card will fit the mainboard, all graphic card with the AGP socket will fit, there is no limit here.
When adding a bigger graphic card, the power supply can be too small for the system.
I would suggest a 400 watt psu or bigger, for a smooth running system.
A more expensive graphic card is always better, depending what you have to use it fore.
More system memory (ram) can also help, if you intend to playing games.
The newest AMD driver can be downloaded here:
By selecting the graphic card model, and your windows system.
Hope this will help you
Mar 19, 2013 | Computers & Internet
Sir! i have winfast NF4K8AC motherboard with Vga display card 128 MB DDR (ROHS Compliant Lead - Free). It was working 6 month smoothly but now I am having problem with display .I have checked the same Vga...
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
hope this helps
Aug 16, 2011 | Foxconn NF4K8AC-RS-1.0 Motherboard
Foxconn motherboard n15235 no viedio
That motherboard is either a P4M800P7MB-RS2 or a P4M800P7MB-RS2H, even thou it has N15235 stamped on the board. The board
Supports VGA display function (S3 Graphics UniChromeTM Pro IGP)
but, also has an AGP 8X slot. A slot that allows you to install a AGP 8X (AGP 3.0) card. A AGP 8x is the VGA interface specification that enabled enhanced graphics performance with bandwidth speeds up to 2.1 GB/s.
Hope that answers your question.
Apr 23, 2010 | Foxconn 6627MA-RS2H Motherboard
I bought Foxconn 755A01-6EKRS Motherboard for my HP pc replacement. i install my AGP VsionTek x1300 graphic card and turn it on and nothing show up on screen...then i put the graphic card back to my old HP...
Your new Foxconn motherboard Primary Graphics Adapter settings in set to onboard vga that is why there is no display in your monitor. Do not install yet your agp video card. Use first the onboard vga of the motherboard.
Power up your computer and go to the BIOS settings. Locate in bios about the Primary Graphics Adapter settings and then select AGP. Save changes and the exit. Turn off your computer and now install the agp video card.
Dec 16, 2009 | Foxconn 755A01-6EKRS Motherboard
No on board graphics after power up.
there are only a few things i can think of that might help. recheck to make sure all of the power supply cables are plugged in, although im sure that you've allready done that. you don't wan't to clear cmos due to the fact that you only do that if you are going to reflash it. could mke it unbootable. try going in to cmos and enabling quick boot this bypasses POST test and might get you in. also try reinstallling the Operating system as this load drivers for your display. the only other thing is you might have recieved a faulty motherboard, this happens mor frequently than you might think.
hope this helped.
please rate good.
best of luck.
Mar 02, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Does a Foxconn 633 m02 motherboard have pci express slots?
You have a Foxconn G33M02? then you have PCI express ports, so you'll need to look at pci express video cards to fit on your pci express x16 ports (the long pci-e port, probably blue colored) on your motherboard.
Jan 03, 2009 | Foxconn VGA FOXCONN 8500GT-512 R PCI...
Needing to know what graphics cards I can get with my motherboard
I can not find it supporting that model but from what I have found it will support a NVIDIA GeForce 7800.
Graphic card
you can use any AGP card up to 8X
Must be AGP NOT PCI-E and not faster then 8X
Jul 23, 2008 | Foxconn (865G7MC-ES) Motherboard
Foxconn WinFast 6100K8MB-RS
Hi tecnoreaper, you're Foxconn 6100K8MB-RS motherboard can use a single PCI-E x16 graphics card. As seen in you're manual on pg. 4, motherboard layout. If you do not have you're manual you can download it from the link below.
After instaling you're PCI-E graphics card you will need to enter you're bios & set "Init Display First" setting to PCIE page 41 in you're manual.
Here are a few PCI-E x16 cards you may want to buy.
I do know that XFX GeForce cards do carry a Lifetime warranty.
At the bottom of this link you can pick the total ammount of memory you prefer you're graphics card to have.
Foxconn suggest you use any one of these PCI-E cards.
but you can choose what ever you wish.
Mai web site for you're 6100K8MB-RS board.
If you need or have more questions, feel free to post them here.
May 18, 2008 | Foxconn 8400GS-128 PCI Express Graphic...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
