Question about Singer Sewing Machines
I have model #9920. The thread keeps wading up in
The thread keeps wading up in bobbin housing. What am I doing wrong?
  • 136 Answers
Most likely not threading the top thread correctly.
Posted on Jul 04, 2009
My machine keeps showing the bobbin error but there is nothing wrong in the bobbin
Assuming you have threaded the bobbin case correctly, you might try using a different bobbin. There may be something wrong with it. Make sure that there is no thread sticking out of the side of the bobbin.
If there is a bobbin thread sensor, it could be dirty causing it to not read the bobbin correctly.
When you thread the upper thread, be sure to ALWAYS RAISE the presser foot so the tension disk is released and the thread can seat properly.
Oct 11, 2016 | Bernina Artista 640E Sewing, Quilting and...
My pfaff 4.2 keeps saying remove thread jam under the stitch plate. I have cleared everything several times but it keeps coming up on the screen.
Candace, while not familiar with the 4.2, I've had thread jams on my trusty old Pfaff. I hope this helps!
If you are able to totally remove the bobbin cover/stitch plate, please do so. Ideally, there will be one or two screws holding it in place.
remove the bobbin
carefully inspect the bobbin housing; thread likes to hide behind the housing. If you find some thread, use a tweezers to remove it.
If no thread is found, see if there are one or two screws holding the bobbin holder/raceway in place, or just a lever. Try to remove the bobbin holder, carefully noting what the orientation is of all pieces is (using a cellphone to capture pictures of before and after is great!).
Clear any threads from the raceway, carefully re-assemble everything, test and good luck!!!
Apr 22, 2015 | PfaFF Sewing Machines
Keep the thread from collecting on the arm that holds the bobbin case in? My Brother LB-6800 sews quilts, and embroiders great until yesterday, The thread wraps around this small arm every time now.
Try taking the bobbin case out and re-insert. It sounds like the case that holds the bobbin is not inserted correctly. You might also try checking to be sure that the needle is inserted properly. Sometimes the needle gets loose and drops down too low. unscrew, push the needle up as far as it will go, then tighten the screw.
Jan 24, 2015 | Brother LB-6800PRW Project Runway Limited...
Bobbin case inserting wrong
I suspect the "housing" you refer to is not seated completely. Be sure to wiggle it until it slips into place. Once it is seated, the bobbin case should seat firmly as well.
May 02, 2017 | PfaFF Sewing Machines
Kenmore sewing machine jams and breaks the needle
always make sure the needle is inserted correctly and all the way
up into the needle holder
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin case is inserted correctly in to the machine
if it's a front or side loading bobbin case
make sure the top thread has not come off the top thread take up
lever
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 01, 2012 | Kenmore Sewing Machines
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
My needle thread keeps breaking. It seems that the bobbin holder is also loose and flopping around. It makes this cha-chunk noise then the thread is broken, usually with the first stitch or two. What am...
Sounds like it needs a cleaning underneath the bobbin case, lint or thread can be trapped underneath. Use a new paint brush to do this then oil it according to your manual.
Sep 18, 2017 | Kenmore Drop-In Bobbin 16231 Mechanical...
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
I keep having the same problem. I have the 7133 sewing machine and the top thread keeps getting stuck on the bottom. It's not the bobbin thread that does it but the top thread which gets caught on the hook...
Sounds like insufficient tension on the top thread. THIS may be due to variation in the thread itself or incorrect adjustment.
ALSO I recently found out that some bobbins have a metal core that can catch the thread as it goes over. The person recommended using the plastic bobbins that have smooth angled sides.
Nov 20, 2009 | Euro-Pro Shark 80 - 7133
Getting the Bobbin threaded in the Machine
when this has happened to me, the upper thread has somehow run amuck. check to make sure the top thread is STILL routed properly. It might have nothing to do with the bobbin.
Sep 05, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
