Question about Toshiba Satellite L300D-ST3501 Notebook
Black Screen I was attched to a projector and pressed F4 and l think F5 the picture went to the screen but my screen went blank, and l have not been able since to get anything on the screen when l start it up.
  • stanchapman Jun 28, 2009
    Thanks fro your suggestion. I am not attched to the projector and connections were removed while my screen was blank. This was a conference so cannot connect to the same projector?
  • 2,229 Answers
You pressed the FN key and whicever special function key controls the video display.
There normally are 3 settings. They are (not necessarily in this order) 1) put the video on the external monitor, 2) put the video on the computer's monitor, and 3) put the display on both monitors.
If you have no display showing, try pressing the key combinations several times. If you still see nothing, try connecting the computer to an external monitor to be sure it works.
Posted on Jun 28, 2009
  • Art Ellison
    Art Ellison Jun 28, 2009
    You can connect to any monitor--doesn't have to be a projector.
  • 237 Answers
Have you tried cycling all the way through the options with the F4? Most laptops toggle in a manner similar to: 1) Laptop only, 2) External display only, 3) Both displays, 4) Back to Laptop only (cycle repeats).
  • PokeyOkie
    PokeyOkie Jun 28, 2009
    You can test by connecting to any monitor, such as one at home or work. It doesn't need to be a projector nor the same unit as before.
Where can i find the minute and second key
In Run screen, press OPTN>F6>F5 (Angl). The Degree/Minute/Second key is the TAB above the F4 Key.
To use the key for example to type in 58 deg 33 minutes, 27 seconds type in 58, press F4, type in 33, press F4, type in 27 then F4. Press EXE. The screen displays 58.5575.
A new tab appears above F5. Press it to convert displayed result to DMS
Feb 08, 2013 | Casio FX-9750GPlus Calculator
Hi. Screen blank for Samsung NPN130? Was working but suddenly went blank but computer working
Hi
have a look on the top row of keys on the keyboard and check if you accidently press the screen off key could be one of these keys F3 or F4 or F5
it may be worth trying to start up pressing the F8 key as soon as you press the power on key
and if you can read the writing on the screen then choose the last known good configuration
and see if windows can correct the problem when it restarts
Apr 26, 2011 | Samsung N13013B Netbook
Cannot display desktop on projector for Compaq presario v4000
Firstly connect your projector to the pc and then press function f4 on your pc.remember to switch you projector to the pc mode
Apr 10, 2010 | Compaq Presario Notebook
I have an Acer Aspire netbook that I want to hook to a projector. I finally got the right cord to hook it up, but it will not display on the projector screen.
One of the F keys will toggle between the Laptop Screen and the VGA output - look at the F keys and see if one has a picture of a screen often F4 / F5 - needs to be used with the FN key
FN key+ F4 Key (Or which ever key has the symbol on)
It will toggle between <laptop screen only><laptop screen and VGA output><VGA output only> Not necessarily in that order
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
DVD video shows on laptop, but black on projector.
Assuming you are connected to the projector via the VGA port On the laptop, you will need to select the VGA output to work - there will be a picture of a screen on one of the F keys at the top of the keyboard, F4, F5 normally on laptops, but can be any of the F keys ----- (assuming F5 as an example ) use the FN key and the F5 key together it will then toggle between the following <laptop only><laptop and VGA output><VGA output only>
Mar 22, 2010 | IBM ThinkPad R52: R52 P M 760(2.0GHz),...
When I plu-in the VGA cable my screen goes blank on my HP-1170. I then have to reboot to fix video on laptop. Done all the resolutions and I cant seem to get the external projector to show anything other...
reset the settings to factory default through the menu. swap out the cable. depending on your laptop, press function-f4 or function-f7. if still nothing, you may have a main board issue.
Dec 27, 2009 | 3M MPro110 Micro Professional Digital...
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
No Signal
On your notebook press fn key and look for F# key that has a monitor or lcd picture on it( ex: F5 or F4). and press on it as well while holding down fn on keyboard
Apr 08, 2008 | Optoma EzPro 739 Multimedia Projector
Toshiba Satellite L300D-ST3501 Notebook Logo
269 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
