Question about Samsung Televison & Video
My tv does not come on yes it is plugged in - Samsung Televison & Video
    President:
  • 1,077 Answers
The most likely the tv has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
My TV shut off yesterday and won'tn turn back on. When its plugged the light isn't on. Usually when its off its red but its neither.
U check the power sourced like the other equipments that plug into that a/c power outlet work?Yes,than tries tv unplug,replug it back like about an hour later by letting the tv to do a resetting itself back to the factory setting.The tv now it should be working again.If the tv still have the same result?Yes,than the tv have a power supply board it is dead.That the board where the power a/c cord plug into it.U have some basic mechanical skills like take things aparts and putting it back togther again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power suppy board for the replacement.
Aug 18, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
8 time stdby led binking
Disconnect connector SS33 from the SS board. Plug in the TV and turn it on.
Does the TV power up and
stay on? No replace the D board. If Yes
Disconnect the TV. Use a volt-meter and place the positive probe on the anode of D280 on the SS board , while the negative probe is grounded. Plug in the TV and turn it on.
Is there approx. 2.7V at the anode of D280 on the SS board? No
Replace
the SS board
If Yes Panel is bad!
Feb 22, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Tv won't turn on and I've checked the obvious like yes the power cord is plugged in yes I've switched the batteries in the remote so I know that is getting power
Try tv unplug,replug it about an hour later,let the tv reset it self.Still have the same problems.The power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 24, 2010 | LG 42PC3D 42 in. Plasma Television
Do acer 5720 have tv card
The TV card is an option. Search for the following: Acer Aspire 5720 AverMedia TV Tuner Driver
May 16, 2009 | Acer Aspire 5720 Notebook
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
Hooking to television
first, does both tv and reciever have plug ins at the back? (mostly does the tv)if the tv has audio input or (red) plug in, then yes...if tv has no plug ins, you cannot.
Jun 10, 2007 | Kenwood VR-405 Receiver
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
