Question about Philips 27PT543S 27" TV
My tv fickers and shuts off ?
My tv fickers and shuts off but the green light stays on it also makes a clicking sound when it flickers and that sound is normal when I turn it on but its a single click and your watching! oh my model is a 27PT543S37A not 27A its a 37'' but it wasent on the list.. thanks
  • thinkitout Jun 28, 2009
    I've smacked a couple of difrent times in various places but nothing changed
SYMPTOM:
Clicks and turns off after turning on set when cold. Have to turn on and off several times to work, or keep changing channels, right side of screen is black for a while.
PROBLEM: It is almost always a bad transistor and a bad capacitor. (about $0.70 in parts)
SOLUTION:
This repair is fairly straightforward. You will need a soldering iron, a solder ******, and a small torx bit. Unplug the set. Lay the TV on the floor, screen down. Remove the torx screws holding the rear cover on. There should be 10, (don’t forget the 2 by the input panel). You will see 2 circuit boards, the one of interest is the large one near the bottom of the set. This board has a retainer clip on each side that needs to be pulled out to allow the circuit boardmy tv fickers and shuts off ? - 2.gif to slide out. Slide the board out about 5-6 inches. You might need to support the board so it doesn’t slide back down into the TV set. This circuit board should have numbers by each of the components. You want to look for 7461 (transistor) and 2455 (capacitor). They are located right next to each other near the center of the board. The transistor will usually overheat and discolor the circuit board immediately around it. Warm up the soldering iron and get the solder ****** ready. Heat up the solder joint while removing excess solder with the ******. Once the transistor and capacitor are free, check the numbers on each. The capacitor (round cylinder) should have “47uf” on it. The transistor should have “C33725” on it. You can order these parts from Digi-Key (google it) for about $2.50 including shipping if you use USPS option. The part numbers are: 493-1060-ND for the capacitor and BC33725-ND for the transistor. Once you get your parts, solder them in and check TV operation. It should work as it did before. This repair can be done by anyone familiar with a soldering iron in about 30-45 minutes their first time. Good Luck!!
Posted on Sep 17, 2009
  • Hope4U1now Mar 09, 2011
    Thank you for your hints! I replaced just the capacitor and it works like a champ. My picture has always looked great, once it decided to stay on. Now it comes on like it is suppose to.
    Thanks again!
  • 69 Answers
Give it a firm Smack on the side . this
will tell you if you got a bad solder on
the main board. and if so its not hard
to fix .later model philips are know for
this problem
Posted on Jun 28, 2009
  • Robert Sheehan
    Robert Sheehan Jun 28, 2009
    give it a firm Smack on the side . this
    this problem
  • Robert Sheehan
    if you decide to take it in tell the repair shop that
    it smaking it fixed it ,that way if it is just bad solder
    they cant charge to much , I would charg about 85.00
    and if i had to replace parts around 110.00
Panasoni TH42PH9UK works for 5-60 minutes then sound and picture goes out. Green "on" light remains on (no blinking) and tv somtime comes back on or flickers on and off. TV is 2007 and does the same
It may be overheating.
Check the vents in the back to see if they are clogged.clean out any dust or lint. Alum if necessary make sure there is room for airflow around vents . Check to make sure blower fan is operating correctly.
Hope this helps.
Bob
Jan 15, 2014 | Panasonic TH42PH9UK 42 in. Plasma...
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
Power on red light and green light fickering but tv doesnt start
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 25, 2012 | Televison & Video
52" tv making clicking sounds
Does the blue light just stay steady or does it blink? Also please tell me the make and model of the tv. Sounds like a problem due to capacitor plague but I would like to be sure.
Sai.
Dec 12, 2010 | Philips Televison & Video
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
WHY WONT IT COME ON?!?!?!?
If you would like us to help you, you must tell us what brand and model TV you have.
Aug 28, 2007 | Televison & Video
Philips 27PT543S 27" TV Logo
405 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
