Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Undifined problem Hi,I'm using a 2gb kingston usb (DTI cn952048 28032-101 AOOFL CHINA). I've recently encountered a problem with transferring data. I copied a word file (about 500 Kb) and could'n read that file again. Sometimes, it seems to to be overwritten by another file, for example I open that file (It still has the .doc extension and correct file size) but it show the content of another text file that i stored before in the usb. I also copied a jpeg file and brought to other machines, there they could'nt detect the type of file, even though in window explore it still show the file name with .jpg and file size.Hope that I described the problem clearly.Any advice would be highly appreciated.Cheers,S.P.
  • 36 Answers
You want to Check Disk for errors as soon as possible. If using Windows, right-click on the drive in My Computer, click on Properties, then the Tools tab, then the Check Now button, then the Start button.
This can happen with any drive if the connection to the drive is lost too soon after saving a file to it. Always use the little 'Safely Remove ...' icon for the drive first, before removing any flash drive.
When a file is saved, the data has to be written to available clusters, the directory has to be updated, and the cluster map has to be updated. In this case, it appears the directory was updated, but either the cluster map had not been updated so that the clusters were still available to be overwritten by a later file, and/or the data itself had not finished being saved, so the old contents of its clusters were still there.
Posted on Dec 06, 2007
Kingston dti/2gb usb fd file system is unknown
might be encryoted,, format if you do not need the information
Jan 12, 2014 | Kingston DTI/2GB Data Traveler 2 GB USB...
How to format DTI/2Gb
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this or if i have missed the problem post a reply
hope this helps you
Oct 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Cannot format my data traveler DTI/8GB
may be its infected with virus
try to Do a virus scan on another laptop or pc
or do a disk difragmentaiton & than try to reformat it
Jan 03, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
32 gb kingston pendrive makes my laptop hang
This is a bug from the operating system, turn off you're laptop, plung the stick and power on the laptop.
Dec 16, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kinston pen drive reads zero bytes
Hi sirmac,
If formatting doesn't clear up the problem then it just needs to be replaced. Contact Kingston Tech Support for a replacement.
Dec 14, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SecureTraveler MFC Application has encountered a problem
it is infected with virus, check it with updated virus remover
Jul 23, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
MFC application in kingston data traveller encountered problem and needs to be closed
how did you try to format ?, try to unistall the driver when complete put the drive back in usb port. if that doesnt work keep the drive in port and open my computer right click on your thumb drive and go to properties click on tools and try error checking. this is probably where you try to format. once test is done pull drive out and reboot then put drive back in
Feb 27, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
107 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
