Question about Dell 946 All-In-One InkJet Printer
Right cartridge missing
Refilled orginal cartridges on a Dell 946 computer and the printer keep saying right cartridge missing.
  • 1,555 Answers
Put an original blank cartridge and then tell me wether it tells you the same. Then I can deffinetly help you out further with refilling solutions.
Posted on Jun 28, 2009
Left cartridge missing
I had the same problem, but with the right cartridge. The only way I could get it to work was to buy a new cartridge. I don't know if it was a bad cartridge?
Jun 09, 2012 | Dell 946 All-In-One InkJet Printer
My printer want print black but have a new cartridge i have a 946 dell printer ...it keep telling me right cartridge missing
You could clean the black ink cartridge. For this you need to remove the blank ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Nov 16, 2010 | Dell 946 All-In-One InkJet Printer
Left ink cartridge incorrect. It is the right ink
A trick which may work is cleaning the contacts on both the cartridge and the printer.
Make sure you've switched it off first, I'd try gently buffing with a soft dry cloth first.
HP reccommend using distilled water and cotton buds, but not alcohol based cleaning fluids.
Allow the water to evaporate before replacing cartridge and switching on.
May 11, 2010 | Dell 946 All-In-One InkJet Printer
My printer keep saying left and right cartridge incorect
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Dell 946 All-In-One InkJet Printer
Window says right cartridge missing. There is a
take out the cartriage and make sure both the cartriage and the holder is clean, replace the cartriage and restart the printer. If this does not work let me know and i will suggest more solutions
Feb 23, 2010 | Dell 946 All-In-One InkJet Printer
Dell 946 new ink still says low ink
You can't. Certain cartridges are not able to indicate a fully charged cartridge after having been refilled. This is due to the fact that they have an ROM chip---Read Only Module--that is not programmable after it has been "used up" by indicating an empty ink reservoir.
Mar 30, 2009 | Dell 946 All-In-One InkJet Printer
Dell 946 A10 Printer will not accept genuine Dell Cartridge
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Dell Photo 964 All-In-One InkJet Printer
My Dell 946 All in One displays 'Right Cartridge Incorrect'
Install old cartriage, if you still have it, let the machine tell you that it is empty, then go through the install process with one of the new ones.
Dec 19, 2008 | Dell 946 All-In-One InkJet Printer
Dell 926 printer
Dell cartridge are quite expensive, and refilled and non original cartridge are often not accepted by Dell printer. If you use non original cartridge often you keep getting this message unless you replace both cartridges.
Be also careful also if you use refilled, sometimes refilled can leak all over the inside of your Dell printer right when ink is coming to the end.
In your case try replacing both cartriges at the time, this usually clears the error.
A suggestion: Dell small inkjets are sold at a price often inferior to the cartridge set price, and now you know why, ask the price for a new Lexmark, HP, Epson,Brother, Canon etc. next time you have to replace a cartridge set, it may be worth buying a new printer.
Apart small inkjet sector, Dell produces excellent laser printers, computers, laptops and more.
You can read more opinions on small dell inkjets here or using google.
Aug 18, 2008 | Office Equipment & Supplies
Refilled my Dell Ink Cartridge
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
Aug 09, 2008 | Dell 922 All-In-One InkJet Printer
Dell 946 All-In-One InkJet Printer Logo
173 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
