In the dehumify mode there is no water appearing in the external tank
  • hockeyref Jun 29, 2009
    The air conditing works fine. It's the dehumidifier that is the problem. Even in the dehumidifier mode the air conditioning kicks in.
    Scholar:
  • 70 Answers
Check to see if fan is running. If so compressor could be out of freon or have electrical or machanical failure.
Posted on Jun 28, 2009
ECOAIR Dehumifier
That appears to be a subjective measurement. Does it cycle off or does it continue to run. What is and was the relative humidity. What was and is the temperature. Ask yourself the above questions and you may get your answer. If it is cycling it is at setpoint. If the room is dryer there is less to remove. The temperature effects the rate of water removal.
Jan 25, 2014 | Dehumidifiers
My husband saids run the dehumifier on low setting to take out dampness in the basement? I said no, run the dehumifier on higher setting like 50 or 60 to take more water out of he basement? What should...
Actually, your husband is correct. The settings reflect the amount of humidity you want to remain in the house. I really don't think you want to leave 50 to 60% humidity in the house.
35% removes the greatest amount of humidity.
Hope this helped answer your question and thanks for choosing FixYa.
Sep 16, 2011 | Haier HDN655E Dehumidifier
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
I have a danby premiere model DPAC10071 & the dehumifier now wont fill external tank. every 2-3 minutes it makes a noise kind of like a fog horn way off in the distance(as if its trying to run again,...
it sounds like your compressor is failing to start ... that usually means a bad starting capacitor ... if thats the case it will hum loudly for a few seconds periodically .. thats the compressor trying to start but it cant if the capacitor is bad .. it will stop humming when it gets too hot .. a thermal breaker will turn off the power until it cools back down .. dont let this continue since it will eventually damage the unit ... replace the capacitor .. the capacitor is usually mounted on or near the compressor .. it often has two sections .. one for the fan motor and one for the compressor ... since they are both in one case you have to change them both ,...
Aug 15, 2010 | Danby Heating & Cooling
My Danby Premiere DPAC 13009 is leaking water through the bottom. I have attached the continuous drainage hose, and no water is going through it. I tried to manually drain the tank using the drain at the...
Water is collected from cooling mode, not just dehumidifier mode. It does not always evaporate into the exhaust stream due to design limitations.
Of course the water should never leak even on the hottest day. Two suggestions:
Try removing the hose and attaching the external tank to see if it has any effect. Otherwise, you'll need to locate the exact source of the leak.
May 25, 2010 | Danby DPAC12031 Air Conditioner
External tank not filling
I recently encountered the same issue. First off, with the external tank installed is there an icon on the display panel indicating the tank is installed?
No? Then the two sensors are not picking up the magnets in the the "arms" on the back of the tank. It's a poor design for sure, on my unit the tank does not sit flush enough to the back of the AC, if I held the tank firmly to the back the icon would come on. I just used a bit of cardboard at the bottom of the support tray to press the tank firmly to the back of the AC.
Theory is as the external tank fills up, water will run into the "arms" and raise the magnets tripping the switch which tells the unit it needs emptying. But the magnets in the arms are not strong enough if they are not close enough to the sensors. So my cardboard solution lasted only one tank.
I ended up getting some flat neodymium magnets (that I scavenged out of a hard drive), and taped to the sensor that had the gap. I wouldn't recommend doing this to both sensors since it would eventually overfill, only one sensor needs to "trip" for the compressor to turn off.
If you answered yes to the first question (the bucket icon is there), then it's most likely the pump not working on the internal reservoir, or something related to that. Can't help you there...
Aug 01, 2009 | Danby Portable Air Conditioner
Red light is on???
You need to empty the water in the tanks, there are two one is external the other is internal if you do not have the external tank attached do so and with the unit of, then turn the unit on and put it in cool mode and watch for the water to drain if this does not work emty the water from the scre holes with the unit unplugged and drain it outside you will need leverage as it will need a slight tilt to do so. Hope that helps..
Jul 31, 2009 | Danby DPAC120068 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
