Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Refigerator will not saty cold but freezer works
Refigerator will not stay cold but freezer works
  • Anonymous Mar 14, 2014
    And refigerator not working well
  • 544 Answers
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Jun 28, 2009
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
Our Electrolux side by side refigerator freezer is not working properly. The freezer will not maintain at 0 F. Instead, it continously drops and stays at -26 F and runs all the time.
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jun 20, 2011 | Refrigerators
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
My side by side G E Sub-Zero is not getting or staying cold on the refigerator side, the freezer is working, what could be the problem?
check to make sure the damper door between the freezer and refrigerator is operating and not iced up so it can open fully to let cold air in from the freezer compartment
Dec 25, 2009 | Sub-Zero 632 / S
The freezer is on top and stays cold but the refigerator is warm what is the solution
check the fan on the refrigerator, maybe it's not working , thats is the reason why there is no ventilation or distributaion of cold air in your refrigerator.
If it is damaged, just ask a technician to replace it., check first the fuse in the connection, maybe it is busted before thingking of replacing a new fan blower
Nov 01, 2009 | Crosley CFFH10W Top Freezer Refrigerator
Bottom wont stay cold top frezer it work bottom ref. wont saty cold and the light work and the fan blowing so im looking for why it wont stay cold at the bottom reg.
make sure you don't have the air flow passages in the back of the freezer blocked with food items or frost. if you have alot of food or items in the freezer and its packed tight it won't let the cold air circulate into the bottom unit
Jul 24, 2009 | Refrigerators
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
320 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
