Question about Kodak EasyShare V530 Digital Camera
Memory card needs formatting
I can turn on but when I press review to look at phots it reads memory card needs formatting - still does this despite inserting new memory card
  • 508 Answers
Did you format it?
Posted on Jun 28, 2009
Memory card requires formatting, press continue then it states that it will delete everything on memory card,then it does not format, it tells you that you need to format memory card. press cancel and...
Hope you have this figure out if not here goes. Sounds as if the camera is caught in a feed back loop. As long as you have down loaded and saved your images on the computer go ahead and format the card. When it says delete everything on the card select OK and click the start button everyone is happy again. By the way all new card and card after doenloading to the computer should be formatted in the camera. Never format in the computer and deleting images one by one is just a great way to totally mess up a memory card's mind. Format, Format
Dec 09, 2010 | Kodak EasyShare Z7590 Digital Camera
I have a brand new PENTAX E70L camera, with SD memory card. i took a few photos on it and then turned it off. Now when i turn the camera on it reads -card requires formatting.I press continue , to format...
Make sure you don't have any pics on the internal memory. To be sure, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert the card and go into the menu and do the format thing again to erase the card and optimize it. Use the menu and not the format option the camera has been giving you.
Sep 28, 2010 | Pentax Cameras
I have a Casio EXILIM EX-S10 "Memory Full" Error
Firstly, charge your battery fully. This should solve the switching off. It sounds to me like your card isn't in correctly, or is incompatible, and your internal memory is full. (it usually only stores a few photos for emergencies) Have a look at the type of card you have. If it says SDHC, or is 4GB or larger, it is not compatible with your camera and you need to get a 2GB. If not, it may not be inserted correctly. Push it all the way into the slot and it will click when it's in properly. Then try formatting it. Press review (where you look at the photos) and scroll down to setup- then look for 'format' and press okay. This should sort everything out. You can also copy the photos you've taken in the meantime from the memory to the card by pressing copy in the review menu and scrolling to the right. Hope that helps
Jul 26, 2010 | Casio Exilim Card EX-S100 Digital Camera
Will not format memory card
How to format the memory card in my camera? NOTE this will delete all existing data on your card.
  1. Do the following:
  2. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  3. Turn on the camera.
  4. Press the Menu button, then go to the Setup Menu.
  5. Scroll up or down to the Format option, then press the OK button
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C913 Digital Camera
    I put my 1GB memory card into the camera and it didnt work
    iput 1gb card in cam i delete allpic?again i want takepic but not working
    Dec 30, 2009 | Digital Blue EasyShare MD1063 Digital...
    V530 camera continue to ask formatting needed.
    Navigate to the 'Format' section of the menu then try each option ('Yes' 'No') separately---checking the advisories between each trial.
    Crat
    Oct 25, 2009 | Kodak EasyShare V530 Digital Camera
    What does no card mean? Thank you.
    "No card" means that either
    1. You have not inserted a memory card
    2. The memory card is not formatted, or
    3. The memory card is damaged and therefore can't be read by the camera.
    How to insert the memory card:
    1. Open the camera’s battery door by sliding it downwards.
    2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
    3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
    Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
    Before you can use the card, it has to be formatted:
    1. Insert the memory card into your camera as described above.
    2. Turn the camera on by pressing the power button.
    3. Use the multi-select button to select the "SET" option.
    4. Press the right arrow button to set "System" then press down key to select "Format".
    5. The default option is ‘Format’. Select this option by pressing the OK button.
    6. Select "Yes" to format the card.
    If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
    Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
    Whenever i take a picture and press to review it says file error
    Hello!!
    Try formatting ur memory card once and reload it ...
    Apr 20, 2009 | Samsung Digimax S630 Digital Camera
    Can't perform the first step...copying from memory card to CD!
    There is a possibility that the unit is simply defective.
    Mar 08, 2017 | Micro Solutions RoadStor Pro...
    Pny 4gb sd memory card
    HI,
    Dear Take this card and format using PC but, make sure PC must have updated antivirus.
    This is the best way toreuse this card.
    Regards,
    Rakesh kumar
    Network Support Engineer
    Jul 18, 2008 | PNY 2GB microSD Memory Card
    Kodak EasyShare V530 Digital Camera Logo
    136 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
