Question about Acer Aspire One PC Notebook
ACELLERATION IS DISABLED OR TURNED OFF HOW DI I FIX THIS
I REBOOTED MY ACER ASPIRE X1700 AND NOW SOME OF MY PROGRAMS DO NOT WORK AND WILL NOT LOAD
Where is the CMOS battery on an acer aspire x1700 desk top computer
Most motherboards use a coin size 3 volt lithium battery type CR2032.
Ti help you.
Download the manual for your model computer from this WEB site.
http://www.manualowl.com/p/Acer%20Computers/Aspire-X1700/Manual/65650
Feb 03, 2013 | Acer Computers & Internet
Cd drive in my acer aspire x1700 doesn't open
You are going to need a paper clip. Look fo a small hole next to the switch. straighten the paper clip and put it in the hole in the center. carefully push to activate the mechansium to open the door. Then you can troubleshoot the door. Turn off the computer then pull the power cord from it. Open the computer case find the power cable to the cdrom/dvdcdrw and push it in to make sure you have good connection. If it still doesn't work after this then you can get a new drive for less than $30.00 (usd)
Hope this helps,
Terry
Nov 16, 2012 | Acer Aspire Pc Minitower X1700
What other sound cards would fit in my acer aspire x1700
Do you have reason to believe that the onboard sound that came with your Aspire is damaged? More than likely you need to reinstall a driver for the sound or (If you get lucky) you may just have something muted or turned off.
This sometimes works: Go to the device manager and under "sound, video and game controllers" dis-able Realtek HD audio. Close dialoge box and reboot the machine. Go back to device manager and re-enable the HD Audio.
The driver on your machine may have been corrupted. You can reinstall the driver using the "resources" or "drivers and utilities" disks that came with the machine.
Oct 08, 2011 | Computers & Internet
My Acer aspire 6920 laptop keeps freezing . It will load up fine and then after about 5 or 10 minutes it freezes and says the programme is not repsonding. Noting will work i.e. the mouse won't move,...
HI, what program is show this message? is it always the same program? if so try uninstalling that program and reboot the laptop to see if it will freeze up.
Dec 20, 2010 | Acer Aspire 6920-6621 Notebook
My acer aspire x1700 plays cd and dvd but without audio audio codec is acc8885 audio controller is hd audio
you might need to check if the driver hasnt been disabled.pls do and be fast.
Jul 07, 2009 | Computers & Internet
HOW CAN I GET IT TO PLAY REGION 1 DVD,S?
http://www.videolan.org/vlc/ This program is like windows media play but better since it plays region dvds.
Jun 11, 2009 | Acer Aspire™ T180 PC Desktop
Programming the MAIL button
make sure that you have loaded the right drivers for you keyboard. under control panel go to keyboard ther should be a tab that allows you to configure going to a standard version of outlook ar you may be able to set it to go to a specific url if not using a microsoft product for your mail
Jun 04, 2009 | Computers & Internet
Ps2 on acer x1700 don't work
connect both the mouse &keyboard restart the machine.if then also it not works then there must be some hardware problem&your desktop does not support.try the usb mouse&keyboard.
Mar 08, 2009 | Acer Aspire™ T180 PC Desktop
Acer eData Security Management
try logging in safe mode and reboot the pc after loading safe mode I have had programs crash installing and I loaded safe mode and restarted pc and in safe mode it fix the problem.. so when I restarted pc it worked ok.. the program mighted of corrupted and you might have to uninstall it and reinstall it I dont remember if acer has a app disk like dell,emachines(new),gateway or ifs a full restore disk.. Im thinking that its a app disk.. you might also want to check for viruses. with a program like house call free scanner from trend.. and spyware scanner free adaware. both are good.
if you still cannot login to windows you can run msconfig in run box and disable it in startup but becareful with what you disable
Aug 05, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100 loading problem
when you say it never finishes where does it stop what do you see ?
May 13, 2008 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
