Question about Lands Phones
Storing numbers How do I store numbers in a Vanguard 4001AR phone please?
How do I store #s
Posted on Jun 28, 2009
I have a VTECH phone model Vt 1122 and I do not have manual still and I need to know how to insert numbers in memory.
You can get the manual here. Here's what it says about storing numbers:
Storing a Phone Number in the One-Touch Memory Locations
  1. Lift the handset.
  2. Press the PROG button.
  3. Dial the telephone number you want to store (up to 16 digits).
  4. Press the one-touch button (M1, M2, M3) where you want to store the number.
  5. Hang up the handset.
Storing a Phone Number in the Two-Touch Memory Location
  1. Lift the handset
  4. Press the MEM button.
  5. Press the dial button (0 to 9) where you want to store the telephone number.
  6. Hang up the handset.
Please take a moment to rate this solution if it's what you needed. Thanks for using Fixya!
Jul 04, 2011 | Vtech Lands Phones
I have a GE phone, mod # 2-9223BKC. I want to program numbers in but i can't find the directions, can you help
MEMORY
Each memory button is capable of storing phone numbers up to 16 digits. Memory
locations 0-9 require you to press the mem button for access.
STORING A NUMBER IN MEMORY
1. Pick up the handset, and press the store button.
2. Dial the number to be stored (up to 16 digits).
3. Press store again.
4. Press a memory location button 0-9, and hang up the handset.
INSERTING A PAUSE IN THE DIALING SEQUENCE
Use the redial button to add pauses to a dialing sequence, for example after you dial
9 for an outside line. A pause is approximately 4 seconds long.
CHANGING A STORED NUMBER
To change a stored number, you just replace it with a different number using the
procedure for storing a number.
DIALING A STORED NUMBER
1. Pick up the handset, and wait for a dial tone.
2. For numbers stored in memory locations 0-9, press the mem button, and then
number of the location in which the desired number is stored
Sep 15, 2009 | Lands Phones
Storing speed dial numbers?
To Set: Do not lift handset, Press FNC button
Press the desired “One Touch” Key
Enter number to be stored (remember”0” for external numbers), Press FNC button to save
To Dial Lift Handset, Press desired One Touch key
Jun 26, 2009 | NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
Phone memmory not storing numbers
hi there try to reset your phone enter this code *#7780# or *#7370#....
Feb 18, 2009 | Nokia 6500 Slide Cellular Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Storing phone numbers
enter the phone number, press store/save
Aug 27, 2008 | Motorola Mobility RAZR V3
Programming a number for memory
Memory
Nov 03, 2007 | Uniden Cordless Phone
Storing numbers in memory
1) Pick up the handset and press the STORE button
2) Dial in the number you wish to store
3) Press the STORE button again to indicate that you have completed the number
4) Press the location where you want to store the number (i.e. 1, 2, …9, or 0)
Oct 21, 2007 | Uniden EXP4241 (050633300466) Cordless...
Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
Oct 06, 2007 | GE 2-9438C Corded Phone
Lands Phones Logo
75 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
