Question about Refrigerators
Our kitchen aid refrigerator has a single large door on the top and a freezer on the bottom. Five times over the past 6 months we have noticed that the food in the freezer was not really getting cold enough to freeze. i noticed a build up over some vents in the freezer, I switched the fridge off waited for the ice to melt and restarted the fridge >>> alll ok, until the next time. I dont believe that we left the fridge open to cause the ice build up This is becoming a pain
  • ghorwitz1 Jun 28, 2009
    how much will this cost to fix?, presuming that we didnt leave the door open and there is something broken causing the problem
    Sergeant:
    Champion:
  • 216 Answers
Check the door gasket seal for leakage.
Posted on Jun 28, 2009
    Sergeant:
  • 296 Answers
Hi
Will you have a look at the evaporator coils inside the freezer. Your refrigerator has a control board inside the fresh food section inside the plastic cover where you adjust temperature.
Most fridges will have a bad heater element, a bad defrost timer (or controller if it is electronic) or most likely a bad defrost limit switch. This is a switch mounted on the inlet line of the evaporator with a clip and senses when the evaporater is defrosted so that it does not get too hot and start melting parts. This switch should have zero ohms of resistance when cold (below 40ish) and be completely open when above 40 or so. The easiest way to test it is take the wall covering the evaporater off and locate the plugs for the swiths. Test continuity through it. If it is sitting in ice, it should have no resistance. If it is open and in ice (infinite resistance) then it's bad.
Your freezer sounds like the self defrosting function has failed. If the evaporater coil freezes up, it gets really cold, but the air in the top of the freezer gets warm, so you could have stuff towards the top of the compartment melting, while the bottom is super cold. The heating element, thermal limit switch, or the timer could be bad. I am not particularly familiar with this model, but most have a little timer motor mounted behind the toe kick somewhere that contrlos the defrost intervals. The timer sends power through the thermal limit switch, located on the inlet tube of the evaporater (coils that get cold in the freezer) and keeps the heater from over heating. This part is probably the most common failure. From the switch, power goes to the heater element, which is mounted directly to the evaporater. If the heater looks kind of like a bake element style (similar to what you'd find in the bottom of your oven) then its probably not bad. If its a glass tube style, then they fail more commonly. Hope this helps, good luck! P.S. this could all have been caused by a door left slightly ajar overnight too...if you think that may have happened, then just turn it off and leave the door open for a day or 2...it'll defrost and be fine! thanx for contactin Fixya
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Ice forming in the bottom of the freezer, not from spilled water.
you probably have a stopped up draing behind freezer wall panel
Sep 19, 2009 | Maytag Refrigerators
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
