Question about Ricoh Office Equipment & Supplies
I get a faint gray line down the left margin of the paper when printing on my Aficio CL35000N. This just started happening and I cannot determine why or how to fix it
  • M. Colin DeWitt
    M. Colin DeWitt May 11, 2010
    Is this while copying as well as printing? Is it on all colors as well?
  • 313 Answers
The faint grey line is probably from teh fuser belt being worn you can check this by going to rear of printer open up door and look at the surface of the fusing roller it probably has a build up of toner or worn belt thais makes the lines sometimes.. if the fuser is clean you need to open up the side door and look at the drum and transfer belt sections.. Good Luck
Posted on Jun 30, 2009
Why am I getting vertical Yellow lines on my printing?
It sounds like the laser drum is damaged and not collecting toner correctly. First try cleaning the paper path with laser cleaning paper. If that doesn't sort the problem replace the drums.
Aug 09, 2014 | Ricoh Aficio SP C811DN-DL Printer
Hi Ricoh 1232 copier and printer. Both copies and prints are produced as if the paper feed was slightly delayed and the print moves over about an inch: effect is you have a large margin on the left side...
Is the paper in the tray landscape-oriented or portrait-oriented? If it's landscape-oriented (short edge is fed first) then you might just need to realign the paper fences. There is a screw holding down the gear in between them -- if you remove that screw you can move the fences so that they're both lined up correctly. (Push them both in all the way or out all the way, then reinsert the gear and screw it back down.)
If the paper is portrait-oriented, it may be an adjustment that will have to be made by a Ricoh service technician. It is a simple adjustment to make, and should only take a minute or two if you can have a tech look at it.
Apr 11, 2011 | Ricoh Aficio 1232C Color Copier
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Faint Black Lines
Hi best way to check is to remove the black photoconductor and you should be able to see the little lines on it also check the the black dev/toner unit for the lines. most likely to be the black photoconductor unit though.
Thanks J
Jan 24, 2008 | Ricoh Aficio CL3500N Laser Printer
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
