Question about Microsoft Xbox 360 Console
It just has 1 light at the bottom right section and when i turn it on it says "syestem error. cotact xbox customer support" (the says in in multiple languages) then E 74 www.xbox/support .com
  • 767 Answers
Simple , but make sure you get some one
who has done a few and know the ins and outs
of the procedures , its not hard to kill your
box if you don't know what your doing.
Just something to consider
Posted on Jul 02, 2009
  • 90 Answers
E74 right. A simple X-clamp fix will solve this problem.
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
1 flashing red ring
The lower-right quadrant of the Ring of Light flashes red on the front of your Xbox 3602.gif console. You also receive the following error message in multiple languages on your television screen or monitor:
System Error2.gif. Contact Xbox Customer Support. This message begins with an error code in the format "Exx," where xx is a two-digit number.
The following indicator will flash on and off repeated on the front panel of your Xbox 360 console:
If one red light is flashing and you receive a different error message2.gif or error code than those that were described previously or you don’t receive an error message or code, your console may be experiencing a different issue. In this case, see "References/links."
This problem occurs when your Xbox 360 console experiences a hardware failure.
  1. Turn off your console, disconnect and reconnect all cables, and then turn on your console.
  2. If an Xbox Hard Drive2.gif is attached to your console, turn off your console, and then remove the Xbox Hard Drive. Turn on your console, and test for the error. If the error does not reoccur, turn off your console and reattach the Xbox Hard Drive. Run alternate additional tests by having the Xbox Hard Drive connected and disconnected to see whether the error occurs only when the Xbox Hard Drive is connected. For more information if the on-screen alphanumeric error is E67, click the following article number to view the article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red and you receive one of the following error codes and message: "E67, or E68, or E69. System Error. Contact Xbox Customer Support"
  3. If an Xbox Memory Unit (MU) is plugged in to your console, turn off your console, and then remove the Memory Unit. Turn on your console again, and test for the error. If the error does not reoccur, turn off your console and reinsert the MU. Run alternate tests by having the MU connected and disconnected to see whether the error occurs only when the MU is connected.
  4. If this problem continues to occur, contact Xbox Customer Service. Note If the agent cannot help you resolve this problem, you must return your console to Microsoft for repair.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web sites:
U.S. customers - Online console repair
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
Nov 11, 2009 | Microsoft Xbox 360 Console
1 RING
Outside the United States - Online console repair
http://www.xbox.com/support/
Oct 09, 2009 | Microsoft Xbox 360 Console
One red light
The lower-right quadrant of the Ring of Light flashes red on the front of your Xbox 360 console. You also receive the following error message in multiple languages on your television screen or monitor:
System Error. Contact Xbox Customer Support. This message begins with an error code in the format "Exx," where xx is a two-digit number.
If one red light is flashing and you receive a different error message or error code than those that were described previously or you don’t receive an error message or code, your console may be experiencing a different issue. In this case, see "References/links."
  2. If an Xbox Hard Drive is attached to your console, turn off your console, and then remove the Xbox Hard Drive. Turn on your console, and test for the error. If the error does not reoccur, turn off your console and reattach the Xbox Hard Drive. Run alternate additional tests by having the Xbox Hard Drive connected and disconnected to see whether the error occurs only when the Xbox Hard Drive is connected. For more information if the on-screen alphanumeric error is E67, click the following article number to view the article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red and you receive one of the following error codes and message: "E67, or E68, or E69. System Error. Contact Xbox Customer Support"
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair)
http://www.xbox.com/support/ (http://www.xbox.com/support/) Note Online console repair service is currently not available in all countries and regions. For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site:
http://www.xbox.com/support/contact
Oct 08, 2009 | Microsoft Xbox 360 Console
Red light in bottom right quadrant
Hey there sounds like you might have the red ring of death. Which is usually a hardware failure.
1. Try turning your Xbox 360 on and off.
2. Make sure all your cords and cables are firmly plugged in.
3. Once you have tried all of those trouble shooting tips, turn on your xbox and see if you get an error screen.
4. This will usually be a black screen with multiple languages on it. on the upper left or right corner a letter E followed by a number will appear.
5. If it is an E74 error, then call 1-800-4my-Xbox
6. Microsoft has extended the warranty for Xbox 350 with the E47 error
Don't worry if your warranty has expired they will extend it when you call.
Oct 07, 2009 | Microsoft Xbox 360 Console
Got on red light,E74
An E74 error is when the lower-right quadrant of the ring piece indicator flashes red and displays an error message in multiple languages: "E74 System Error. Contact Xbox Customer Support". The error is caused when there's a video problem with the Xbox's hardware scaler chip being damaged. As of April 14, 2009, the E74 error is now covered by the three-year extended warranty.
Aug 09, 2009 | Microsoft Xbox 360 Console
One red light and E74
You see the lower-right quadrant of the Ring of Light flash red on the front of your Xbox 360 console. You also receive the following error message in multiple languages on your television screen or display: E74. System Error. Contact Xbox Customer Support.
You will see the following indicator on the front panel of your Xbox 360 console, which will repeatedly flash on and off:
If one red light is flashing and you see a different error message or code than the one listed above, or you don’t see an error message or code, your console may be experiencing a different issue. If this is the case, please refer to the “References/Links” section at the bottom of this article. CAUSE This behavior occurs when the Xbox 360 console experiences a hardware failure.... loadTOCNode(1, 'cause'); This behavior occurs when the Xbox 360 console experiences a hardware failure. THINGS TO TRY Here are some steps that you can use to try to resolve the issue. Turn off the c... loadTOCNode(1, 'whattotry'); Here are some steps that you can use to try to resolve the issue.
  1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on.
  2. Turn off the console, and then disconnect any accessories that are connected. For example, disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem still occurs. This can help you determine whether the console or an accessory is experiencing the problem. If you determine that an accessory is consistently causing the error, try borrowing another accessory of the same type and testing again using that accessory.
  3. If you continue to experience this problem, contact Xbox Customer Service.
    Note If the agent cannot help you resolve this issue, you may have to return the console to Microsoft for repair.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web Page links: United States customers - Online console repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair) Outside the United States - Online console repair (http://www.xbox.com/support/) Note: Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Mar 27, 2009 | Microsoft Xbox 360 Console
Red light at bottom of my 360 console and it says error
we had the same problem. called into the toll free number they said they were aware of this problem.....they sent us a box and mailing label we sent it in and 3 weeks later received it back and has worked fine since....KNOCK ON WOOD. Goodluck
Jan 26, 2009 | Microsoft Xbox 360 Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
62 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
