Question about Minolta Maxxum STsi QD 35mm SLR Camera
Minolta STsi Maxxum
The camera is rewinding the film after I have only taken one picture. I thought it was a bad batch of film, but when I purchased a new roll of film it happened again.
Re: Minolta STsi Maxxum
I donn't know what is the part in the right zone is like a blsck roll and the another is a func is another roll but this one is silver with like a eye and "osi","wl"and func in the center
Posted on Dec 26, 2007
0 characters
3 Points
How to rewind film on minolta maxxum 5000?
Open door in the dark room.
See if it's already rewinded, but could be a stuck counter
May 12, 2014 | Minolta Maxxum 5000 35mm SLR Camera
The shutter speed sounds as if it never changes in any of the modes. Is there a way to test the speed other than the picture quality?
Above 1/30th of a second you will not hear any difference due to the way that an SLR camera twin curtain shutter operates.
There are just two tests possible: take the camera to a repair shop for shutter speed testing or just assess the exposures taken when using transparency (slide) film. Assessing the exposure with regular negative film isn't much use as the photo printing machinery can compensate for under or over exposed images.
May 26, 2010 | Minolta Maxxum STsi QD 35mm SLR Camera
Auto rewind on my Minolta camera
Broken gears in Advance Assembly.
Needs service.
Mar 22, 2009 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Rewind runs but film still seems stuck & won't rewind-Max 3xi
It could be that there is a broken or missing gear in the rewind. It will spin but not catch. Sometimes when film is loaded it, is not drawing the film across and missing a gear, so it seems like your taking photos and its not. If you sent it to minolta, good luck, they were bought out by Konica, and probably didnt' do a thorough analysis of it.
I have a friend who fixes cameras. Cleans them, lubricates them, and callibrates them,
Hope this helps you
Dec 30, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Hi - You can download the manual from the link underlined in blue below:
Maxxum 3xi part 1
Maxxum 3xi part 2
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 17, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
You can order one from
Jun 21, 2008 | Minolta Maxxum STsi QD 35mm SLR Camera
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Minolta StSi Maxxum
It's the shutter speed. I copied this out of the manual :
The number 60, or 125, displayed in the
data panel stands for 1/60th or 1/125th of a
• Usable apertures will depend on the aperture range of the lens you are using. • The seconds indicator appears in the
viewfinder and data panel if the shutter
speed is one second or longer.
Albeit copy and paste made it fit weird into here.
May 27, 2008 | Minolta Maxxum STsi QD 35mm SLR Camera
Film advancement
Transport mechanism problem; the drag on the film as it is being pulled by the transport motor triggers the rewind mechanism and your camera rewinds the film. Remedy : remove bottom cover and clean loose dirt and anything foreign out of the visible gear-train. Assemble and try again.
Sep 16, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Minolta Maxxum STsi QD 35mm SLR Camera Logo
130 people viewed this question
Top Minolta 35mm SLR Cameras Experts
Mark Schmit
Mark Schmit
Are you a Minolta 35mm SLR Camera Expert? Answer questions, earn points and help others
