Question about Whirlpool Washing Machines
My washer machine agitates but will not rinse, spin or drain. Thanks
  • 999 Answers
Check the lid/door switch.
Eric
Posted on Jun 29, 2009
Serial # SD117482G
Most likely the control or timer. What is model #?
Nov 17, 2017 | GE WBSE3120B Top Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Have a circa 1999 Kenmore Three-speed clothes washer (Top Loader) that keeps on agitating regardless of the cycle I put it in. Some cycles do nothing at all, but others (such as Rinse) make it just keep...
The clutch assembly works only to release the basket allowing it to spin during the drain and spin cycles. The drain function works only when the spin function works. If the machine also agitates during spin cycles, then the problem is in the transmission assembly not able to release the agitate gear from the agitate spline in the drive shaft.
Sep 30, 2010 | Kenmore Washing Machines
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
My washer will not rinse.
If it spins and drains and washes but will not rinse then you probable need a new timer but check the lid switch first.
May 12, 2009 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Spin and rinse problem with whirlpool washer
check your drain hose and pump maybe something clogging it
Nov 15, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
16 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
