Question about Mitsubishi WS-65511 65" Rear Projection Television
Tv wont responde to remote or front panlle,pressed reset no response
    President:
  • 788 Answers
There are several things that you can do for troubleshooting this symptom.
First, you can test the remote; if you have a camcorder you can film the remote while it is transmitting. The camera can see the infrared diode on the front of the remote. Just turn the video camera on record and shine the front of the remote into the lens of the camera. If it is flashing then the remote is working.
You may want to unplug the television set for 30 min and then plug it in and see if that fixes it.
As you stated in your post, neither the remote or the front panel work to turn the television. It is possible that you have a dead set.
I would recommend that you contact a local service center to come out and diagnose the problem that you are having.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 28, 2009
How come remote hardly ever works?
Note: Instructions below assume that you are having the same problem will _all_ functions of the remote. If you are having problems only with certain specific buttons, then the problem is wear, and there's not much you can do about it, other than pressing down harder and holding until the TV responds. // Instructions for _all_ button functions: Using "Window Cleaner," clean the lens on the TV (usually a translucent reddish color rectangular shape in front of the TV), and _gently_ clean the red diode in front of the remote. Then make sure you have _fresh_ alkaline batteries (not "heavy duty") in the remote. Eliminating those three issues usually takes care of sluggish remote response.
Oct 15, 2015 | Televison & Video
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Tv will not respond to remote
change batteries and if after that no response check light on front of tv should flicker slightly when pressing buttons on remote. if you see a flicker the prob is tv if not its remote
Jan 04, 2011 | Vizio L32 32 in. LCD HDTV
I NEED A NEW REMOTE CONTROL
Hello
I thinks that you need a new universal remote control for your RCA tv, and answers. You just buy one stated below,and codes and other proceedings are also given.
Model No: [RCA - D770 Wide Range Remote Control]
Codes for RCA TV with this remote control are:-
1000, 1003, 1004, 1005, 1006, 1007
.........................1019, 1096, 1098, 1099, 1100, 1101
.........................1102, 1103, 1129, 1179, 1181, 1187
............................................1188, 1190, 1198, 1199
Proceedings
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn't, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
NB: Switch Off and On your TV with its front panel power switch each time [NOT BY THE REMOTE CONTROL HANSET], before you try an other code, UNTIL YOU GET THE RIGHT ONE.
Dec 20, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
My samsung tv is not responding to my remote control, actually even when I go and attempt to change the channel from pressing the up/down buttons on the tv it won't respons, some menu screen would come on...
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Mar 21, 2009 | Samsung Remote Control
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
I saw your response to a question about the Toshiba 32A33 TV ...
Definitely, there is some keypad failure. There is a continuous contact anyone of the key. Since key is contiunuosly giving command to the processor Remote function is automatically cutoff. My simle Tips to find out key failure. Good key give "Tick" sound when you press the key softly. The sound is very very low, you have to observe carefully. Otherwise blindly change all the front panel key. Cost is very very low. When the keypad problem is solved, remote will function automatically.
May 19, 2008 | Toshiba 32A33 32" TV
TV won't respond to ANY remote control
unplug the tv, wait 1 minute so it resets to factory settings then reprogram the remote
Aug 21, 2007 | RCA F36450 36" TV
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
