SCREEN DOES NOT LIGHT UP
WHEN BOOTING UP THE SCREEN IS VERY DARK AND YOU CAN BARELY SEE THE WINDOWS LOGO OR ANY INFORMATION
any help would be gratefully recieved
  • 390 Answers
Hi
just increase the brightness of the screen just scoll on the knobs on the screen and this might help out
hope this helped
pls rate the solution
Posted on Jun 28, 2009
Lost windows by formating the hard drive
Load cd windows disc in dvd unit and shutdown laptop, now power up, when acer logo appears press F12 on the upper part of the keyboard, scroll up or down using arrows on the keyboard, highlight cd/dvd drive and press enter, this will automatically load windows, enter information when prompted. Note! F key number may be different check bottom right when logo appears.
May 27, 2012 | Acer Aspire 7110 (LXADJ0J075) PC Notebook
How to obtain boot options at start?
Hi 04mayuratre,
1) Turn on the computer.
2) As the computer starts, press on the keyboard until the Advanced Boot Options menu appears on the screen.
NOTE: You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen.
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
Dec 06, 2010 | Computers & Internet
Not booting
Would you be able to get the Windows loading bar before it goes to a dark screen if yes we could reinstall the Windows wherein you would lose information on your computer and to do the reinstallation all that you would need to do is start tapping on Alt+F10 as soon as you turn on your computer untill we find Windows loading files on the screen and then you would get the Acer recovery management Windows from where you need to select completely restore system to factory defaults and then keep following the instructions on the screen clicking on a few next ok or yes buttons and it would complete the process in 30-45 minutes time;if you are unable to get the Windows loading bar or the Acer logo then you would haveto conatc technical support and set up a repair for a video card issue.
Jun 06, 2010 | Acer Aspire One PC Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
My dads toshiba A20-S207 has a dark monitor. Can very faintly see the windows xp logo at the beginning of boot up, so it looks like it is booting up, but the monitor stays dark. Can u help?
common LCD dark.dim screen problem, u can google keywords get more information.
either LCD inverter failure or CCFL backlight lamp failure, ask for a pro get it fixed.
by using a flashlight could you see the image on the LCD?
Dec 06, 2009 | Toshiba Satellite A20-S207 Notebook
Dark screen, nothing comes out.
Make sure all connections are tight and secure. Troubleshoot like this.
Can you see the boot screen when it boots up( Before the Windows logo appears.)
1. Check and tighten all connections,
2. Possible monitor went out.
Mar 13, 2009 | HP (D7580-60003) Motherboard
Sony viao, comp. boots up. screen very dark.
Is the screen just dark s that you can barely see what's on it, or is it completely blacked out?
Jul 27, 2008 | Dell Latitude C610 Notebook
Help
If you have a Windows operating system installed, try booting in safe mode. You do this by pressing the 'F8' key after the BIOS messages but before the Windows logo appears. (You can press it several times during the boot procedure.) Then you select 'Safe Mode' from the list. If you can see the screen there is probably just a video setting that needs to be changed.
Apr 11, 2008 | Balance CN6555 Notebook
Sony vaio screen dark then light
your laptop inverter is going bad. need to replace. you can get it on ebay cheap. the inverter is responsible you the lighting up of your screen. thats the solution REMEMBER TO RATE THE SOLUTION
Apr 09, 2008 | Sony VAIO VGN-N130G/W Notebook
might be going into a powersave after it boots...try checking the power options
Feb 28, 2008 | Sony VAIO PCG-K35 Notebook
Computers & Internet Logo
57 people viewed this question
Alun Cox
David Payne
David Payne
